Changed air in my tires.
Discussion in 'Wheels & Tires' started by goaljnky, Dec 19, 2009.
  1. goaljnky
    3,105
    394
    Unless you are south of the Equator.
  2. lotsie
    stagehand/part time detailer
    Right here
    You have to remember that south of the Equator air tends to spin the other way.
    Mark
  3. minimark
    Exactly why you use winter air in the summer at certain altitudes down there....
  4. Sideways
    Sideways New Member
    May 12, 2009
    539
    37
    Above the Border^^^
    You also have to remember to install your air the right way up when you are below the equator as it not only spins the other way but it is upsidedown
  5. lotsie
    Right here
    Only if you use northern air down there.
    Mark
  6. Sideways
    Sideways New Member
    May 12, 2009
    539
    37
    Above the Border^^^
    Right...Northern Air is lighter than southern air...Northern air rises while southern air sinks
  7. minimark
    Yep, northern air is a more gasious state..... :)
  8. Sideways
    Sideways New Member
    May 12, 2009
    539
    37
    Above the Border^^^
    Question...should you heat cycle your Northern Air if you are going for track times???
  9. lotsie
    Right here
    Depends.
    Mark
  10. Sideways
    Sideways New Member
    May 12, 2009
    539
    37
    Above the Border^^^
    On What?
  11. lotsie
    Right here
    Stuff
    Mark
  12. ronnie948
    ronnie948 New Member
    Sep 9, 2009
    210
    36
    Daytona Beach, Florida
    Very bad idea
    I'm telling you that you never ever want to fill a Mini coopers tires with helium becase the car will bounce down the road. The Mini is a light car anyway so the helium will just make it much lighter. Actually the car may blow away on a windy day.
    Helium is just not a good idea!!!!:Thumbsup:
  13. Metalman
    That's why the MINI comes with that loopy thing with the tools in the boot. You screw it into the bumper, then with a short rope, you can tie the MINI to something much heavier. You'll see the loopy thing permanently installed on many modded MINI's. That's how you can tell the ones that are full of that particular gas.:D
  14. cct1
    I've switched to methane. Just drive-through any Taco Bell, and 6 hours later, you're good to go....
  15. Doggybags
    Doggybags New Member
    Did you also prepare a custom adapter?
  16. cct1
    Why yes I did. The cool thing about this adapter is it's dual functionality--not only does it inflate the tires, but it also hooks directly into a 3-inch hose (tried a two inch hose, but it kept exploding under the rapid pressure fluctuations), which I am going to hook up to my rear diffuser when it eventually is in place, thus creating more downforce.
    I'm still in experimental phase, I'll have more data for you once I've track tested it this Monday at Blackhawk. I've had pretty good results with chicken gorditas combo #4, but I'm trying the chili cheese burrito this go around; I'm pretty sure this will be the combo that puts me over the top...
  17. moreorless
    moreorless New Member
    Aug 17, 2009
    343
    14
    In a pile of sawdust.
  18. cct1
    I have to admit, you have a valid point. Here you go:
  19. lotsie
    Right here
    We don't want pics of the device hooked up.
    Mark
  20. cct1
    It's ok, I already posted those over on the Sewing site....
