1st Gen R53 Cooper S Check Your Belt Tensioner Damper
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by minsanity, Dec 14, 2012.
  1. BlimeyCabrio
    Good luck, then. Let us know how I works out.
  2. minsanity
    minsanity Well-Known Member
    Sep 11, 2009
    581
    352
    Easy, guys. No need for hate here, it's the Holidays!
    The reason why Alta came out w/ this was to address the damper's & its bushings' short service lives. Can't fault them for that approach.
    Way, huge thanks for offering the market a great bush-failure solution. Perhaps, you can also help everyone by making available separately a better damper w/o the need to buy the whole tensioner assembly....Pleeez.
    A wonderful Christmas, all!:cornut:
  3. AliceCooper
    AliceCooper Club Coordinator
    Mar 13, 2010
    643
    123
    CT Technologist
    South Florida
    While we are on the subject of belt tensioner, I found this on Amazon with FREE shipping nice little deal, might just pick one up for the hell of it.
    [ame="http://www.amazon.com/Gates-38404-Belt-Tensioner/dp/B001KQJRDO/ref=sr_1_1?ie=UTF8&qid=1355633578&sr=8-1&keywords=mini+cooper+belt+tensioner"]Gates 38404 Belt Tensioner : Amazon.com : Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/31nd-uIROyL.@@AMEPARAM@@31nd-uIROyL[/ame]
  4. minsanity
    Sep 11, 2009
    581
    352
    Great find!:Thumbsup: I actually replaced mine from a Litens(BMW OE supplier) unit. Exact same German-made strut as stock. Not as cheap as that, though!
  5. BlimeyCabrio
    I have the Gates unit on my car now, FWIW. Looks and works like OEM.
    I'll probably buy another as a spare.
  6. minimark
    It is the exact same piece made by the same manufacturer.
    This is one of those parts that MINI rapes it's customers with on the price of the part. :banghead:
  7. Dave.0
    Hey Scott,
    I hate to break the news to you but the new ALTA tensioner part is just a small spherical bearing ended end link. Yes it offers tension for the belt but it it is not self adjusting i.e. manually adjusted and has no dampening at all. Just like the stupid solid lightened crack pulley they sell. ALTA makes very poorly engineered parts with cheap materials that will destroy a motors bearings via unhampered harmonics.
    Back in the day when I was nieve and looking to upgrade my new Mini I too found ALTA parts and bought them. Every single part was of poor quality and failed or did not fit correctly.
    I give ALTA crap because I call it the way I see it. I also do not want others that are new to the Mini community make the same mistakes it I did and waste money on crap parts.
  8. ScottinBend
    Oh we all know your opinion of Alta....seriously.
    I know what the damper replacement is, and I stand by my opinion. We all ran un-dampered/tensionered engines for years w/o issue AS LONG as you checked the tension periodically and made any adjustments necessary. Remember checking the alternator for proper belt tension? All the current OEM design does is to supposedly eliminate the need for periodic maintenance.
    And I completely agree with you about the crank pulley and some other parts, but my experience with a few of their parts has been just fine. I just refrain from giving a blanket statement like you do of them.
  9. Dave.0
    Well to each their own. :D
  10. back from the dead.
    i removed engine from my 05 JCW and see tensioner shock is completely dead
    started brousing and found this. wonder if it has the same dimensions?:
    [ame="http://www.ebay.com/itm/Mercedes-r129-w140-w201-w202-w126-w124-Belt-Tensioner-Shock-oem-Stabilus-new/281564893958?_trksid=p2050601.c100085.m2372&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D37338%26meid%3D96ee09ad53f54899ba3745d22d01c2c2%26pid%3D100085%26rk%3D4%26rkt%3D4%26sd%3D281725159108%26clkid%3D6586628990479736461&_qi=RTM2247628"]http://www.ebay.com/itm/Mercedes-r129-w140-w201-w202-w126-w124-Belt-Tensioner-Shock-oem-Stabilus-new/281564893958?_trksid=p2050601.c100085.m2372&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D37338%26meid%3D96ee09ad53f54899ba3745d22d01c2c2%26pid%3D100085%26rk%3D4%26rkt%3D4%26sd%3D281725159108%26clkid%3D6586628990479736461&_qi=RTM2247628[/ame]
  11. back from the dead.
    started browsing and found this. made in Germany by the same company. wonder if it has the same dimensions?:
  12. MCS02
    Some people replace them every year. I don't do it that often but you do need to keep an eye on them.
  13. Dave.0
    I now replace mine every two years along with a new belt since I do not drive my MINI as much as I used to since I work from home.
  14. Rawhyde
    Rawhyde Active Member
    Apr 7, 2012
    311
    233
    Facilities Engineer
    Mountains of NW Georgia
    The entire assembly or just the damper?
  15. MCS02
    The whole kit and caboodle
  16. Dave.0
