Engine Drivetrain 2nd Gen Cleaned the MAF
Discussion in 'Tuning and Performance' started by Justa Jim, Feb 17, 2011.
  1. Justa Jim
    Well, I have not seen any real signs that I needed to do this, but with all the talk, of late, about oiled air filters, I went for it. It was actually very simple to do.
    I will take a test drive tomorrow and if I see any difference at all, I will post the results.
  2. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    :useless
    :popcorn:
  3. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    I don't know if it as big a deal on these cars but I've done my fair share of MAF cleaning on Fords and it's day and night when they were dirty.
  4. SNEEEZY - Erika
    1,212
    116
    Female
    Wait a minute...let me see if I'm understanding correctly.
    You cleaned your MAF and then you can actually w-a-i-t until tomorrow to test it out?! :shocked:
    Sir, you certainly possess much more self-control than I do!
    Seriously, though...please post pics. :popcorn:
    Erika
  5. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Jim,
    I'm *assuming* that your air flows through the MAF before the air box on a justa as it does on a 'S'. Is that correct?
  6. Justa Jim
    Nope, after. If it was before, then how could an oiled filter cause a problem?
  7. Justa Jim
    Well, I did start it an hour or so after the cleaning to be sure it would. :cornut:
    Test drive in the AM. Night all. :Thumbsup:
  8. Justa Jim
    That, my friend is what I am trying to find out. :Thumbsup:
  9. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    well thats what had me scratching my head
  10. Justa Jim
    I don't know anything about an "S" or a "JCW". If the MAF is "before" the air box, then why is there even a concern about an oiled filter or any other debris for that matter? I thought that is why they told gmodder his problems started. :confused5:
  11. Metalman
    The OEM location always have the MAF after the air has been filtered.
    It helps to keep the birds and such from harming the sensor.
  12. BThayer23
  13. david in germany
    david in germany New Member
    Dec 15, 2010
    250
    the MAF is NOT before the filter on any of or Minis
    oops I missed p2. lol
  14. Justa Jim
    Having it before the filter seemed odd to me, too. The one ben showed is the R56 MC, like mine.
  15. Justa Jim
    Test Results:
    Went on my daily drive to where we keep some of our horses. I know this route and the readings I normally get, so this is where I wanted to try it out.
    I have picked up almost 3mpg. Can't really tell about the idle, since I have the torque arm bushing, but it might be smoother. I have been running a K&N filter the going on 2 years. I would say this helped, but it would not seem the MAF was really, really dirty.
    I now know how to do this on the 2009 justa, without taking everything apart now, so I will repeat a couple times per year. Can't hurt. Give it a try. :Thumbsup:
  16. BThayer23
    Sweet. 3mpg is pretty dramatic. Thanks for documenting the results, Jim.
    I'd say this is something you should do as often as you change your spark plugs, 40-60k miles, or more if you use a reusable filter. Clean the filter, re-oil, and then clean the MAF a week later. My other car has a MAF sensor, and that's the maintenance interval I use.
  17. Justa Jim
    No problem Ben. The more information we capture here, the better. :Thumbsup:
  18. Nathan
  19. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
  20. david in germany
    Dec 15, 2010
    250
    That is actually after the airbox. The air feeds from the bottom of the box and out the top to the MAF in route to the turbo.
