2nd Gen R55 Clubman Clubbie headed in to shop
Discussion in '2nd Generation: 2007+ R55 through R61' started by rum4, Feb 24, 2012.
  1. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    Well my 2012 Clubbie is headed to the dealer tomorrow due to it now wanting to start a few times and then yesterday on the way home it threw the check engine light!!!!!! Wow only 8800 miles and going to the shop. Sometimes when starting it will start, rough idle then die. Almost like it does have enough fuel, leaking injector, to stay running. After reading Nathans issue it may only be running on 3 cylinders cause if you give it a little gas it will for a few seconds it will idle just fine. Hopefully they can get it fixed soon:fingerscrossed:
    Sounds like the HPFP, but that is just a SWAG on my part. That goodness for warranty. They'll get her fixed up so no worries.
  3. Metalman
    I'm with you Chuck.... MINI came out with an extended warranty that covers issues with the HPFP. The dealer will fix it for you.
  4. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    Interesting. Second post-2009 car with start issues I've heard about. Please let us know what the dealer finds. I hope it's a quick fix.
  5. JMC40
    JMC40 Well-Known Member
    Sep 1, 2010
    1,745
    368
    O...H...!!
    Interesting, my 2011 Clubbie has had this issue a couple of times. Never thrown a check engine light, but I will have to keep an eye on it.
  6. rum4
    4,568
    1,475
    SC
    well they replaced the thermostat and had to reprogram the computer due to a rough idle.
  7. Redbeard
    1,636
    398
    Is it happier now?
  8. rum4
    4,568
    1,475
    SC
    yes and so am I. That dam^ Mazda was killing me
