1st Gen R50 Cooper Clutch overhaul.
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by interzonearts, Dec 6, 2015.
  1. Minidave
    This would have been good information to have in your first post.
  2. RallyMini370
    true but this is the Cooper section......those S's have their own section..LOL
    That's why I asked the year due to different 5 speed gearboxes for the Cooper
  3. Minidave
    Thanks for pointing that out.....I get to these posts from the "New Posts" button so I don't always notice which section it's in.....
  4. RallyMini370
    When do you plan to do the clutch?
  5. interzonearts
    interzonearts New Member
    Jul 2, 2015
    64
    31
    i'm fixin' to it, been busy at work but i ought to do it before it gets freezing here. Actually i finally got to it and ordered the parts after you asked, so thanks :)
  6. interzonearts
    Jul 2, 2015
    64
    31
    I ended up having a mechanic do it. But we ran into a problem: the driver side axle popped out of the transmission after few days of driving. The mechanic thinks the lock clip could be worn. He doesn't know if the lock clip is in the axle or on the shaft in the transmission.
    Do you guys have any advice on how to make sure the axle stays in its place?
  7. RallyMini370
    I tack welded the seal cover to the axle , then made a bracket to slot in between the CV joint and cover. Works perfect
  8. Minidave
    Boy, a pic might clear that up a bit - I have no idea what you did there.... :confused5:
  9. interzonearts
    Jul 2, 2015
    64
    31
    I second that motion :)
  10. RallyMini370
    sorry chaps, I'll take a photo soon
  11. interzonearts
    Jul 2, 2015
    64
    31
    That'd be way cool
  12. RallyMini370
    sorry for the delay, I took the photos but forgot to post them. DUH! This is the bracket off the gearbox. There are 2 lugs with holes in that I put extra bolts through to bolt up the bracket.
  13. wmwny
    4,040
    2,242
    Still cannot get through, Chris. It says, "default client not properly installed" or something like that.
  14. interzonearts
    Jul 2, 2015
    64
    31
    Thank you, Chris.
    It looks like you've had it for a while. Did it create any issues?
    How did you come up with it?
  15. RallyMini370
    I've noticed a dribble of oil on some rallies around the LS axle so I figured the axle must be popping in and out so I looked at the gear box, axle and then made the bracket. The bracket has done around 4 rallies and does have a little bit of wear which proves it works
