1st Gen R50 Cooper Control arm bushings on R50
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by M1N1, Apr 8, 2014.
  1. iovecables
    iovecables Member
    May 25, 2014
    72
    City Transit Operator
    Ottawa, Ontario, Canada
    Since the car would be appart, would it make sense to install lowering springs at same time?
  2. M1N1
    M1N1 Well-Known Member
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    Going to order Powerflex control arm bushings, and as suggested probably replace steering rack/sway bar bushings while under there.
    Question; how much of a PITA is it to do the ball joints, and is it worth doing them on a car with Justa over 50,000 on the clock?
  3. Dave.0
    You should not need any of them my car is an 05 with over 75K still on the stock ones. (Ball joints)
    As for the bushings the only ones I replaced were the LCA bushings the other ones are still OEM. Don't replace every bushing just because they make them or you will make your car stiff and everything will rattle.
  4. M1N1
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    Thanks for the info. How do you like the LCA bushings? Powerflex?
  5. Rawhyde
    Rawhyde Active Member
    Apr 7, 2012
    311
    233
    Facilities Engineer
    Mountains of NW Georgia
    I like my Powerflex bushings. I can tell no increase in noise, vibration, or harshness. I've used poly bushings in other cars, and could see in increase in NVH, but the MINI did not have that problem.
    You'll get more precise steering and the peace of mind that they'll last.
    While you're in there, I'd go ahead and put in fresh ball joints. Those things see a lot of punishing conditions, they aren't expensive, and they're right there while you're doing the bushings.
    I'd also replace the steering rack bushing because the inevitable PS fluid leaks will deteriorate the rubber bushing material. I replaced mine with a Powerflex poly bushing because it was easy to get to while I had the subframe out and is more resistant to oils of various types. I can tell no difference in noise etc.
    Let me also amplify what Dave said. Don't replace every bushing with poly. If you overdo them, you'll wind up with a rattling, creaking, buzz box.
    Also, while you have the front end extended in Service Mode, put a fresh o-ring on the crank position sensor.
  6. Dave.0
    Excellent :Thumbsup:
  7. iovecables
    iovecables Member
    May 25, 2014
    72
    A local garage that specializes in Mini maintenance and repair quote me $875 to do the control arms and bushings. Does that sound right?
  8. Dave.0
    Ummmmm I am going to say no. That price sounds a little high.
  9. Rawhyde
    Apr 7, 2012
    311
    233
    Facilities Engineer
    I did my teardown one weekend, and reassembly the next. If I had all the parts on hand, I could probably do it in 10-12 hours. That equates to $72.92-$87.50 per hour.
    For that kind of money, you deserve top notch workmanship.
    I'm an engineer with 20 years experience, and I'm responsible for maintenance, upkeep, and capital improvements for ~26 buildings and 16 enterprise sized data centers. I'm ashamed to say that I don't make that much.
  10. iovecables
    iovecables Member
    May 25, 2014
    72
    That's for parts and labour, in Canadian bucks.
    What would be more reasonable?
  11. iovecables
    iovecables Member
    May 25, 2014
    72
  12. iovecables
    iovecables Member
    May 25, 2014
    72
    Isn't anybody willing to offer and opinion? :(
  13. rkw
    rkw Well-Known Member
    443
    That rate is about average for an independent shop around here, and the local dealerships charge more than double that rate!
    @iovecables, did they quote the number of hours and hourly rate?
  14. clifforddward
    clifforddward Active Member
    Dec 2, 2013
    104
    76
    Cary, North Carolina
    Helix replaced the control arm bushings on my R53 at the recent MOTD for $350 including parts...it was a special they offered to attendees, and as you have found is quite a bit cheaper than what most shops charge. I'm pretty sure they have a method figured out that allows them to do the replacement without dropping the sub frame (which is the typical method and takes more time). My car had 93k miles and the bushings were completely worn out...the new bushings made a world of difference in handling and steering wheel feel.
    You might be able to do this job yourself, many have...one good option if doing yourself is to obtain control arms with the bushings installed on an exchange basis...without the proper tool I understand it is a bit of a bear to get the new bushings in.
    During the install Helix discovered my front sway bar bushings are also worn...but that job does require lowering of the sub frame...so it will have to wait until I've got to drop that for some other job.
  15. Rawhyde
    Apr 7, 2012
    311
    233
    Facilities Engineer
    I haven't been on in a while, but your price isn't so bad if it includes materials. You can look back through my posts and see the scope of work I did. Parts alone were $550-600 if I remember correctly. My earlier reply about the high price was because I thought that was for labor only.
  16. Detroit Tuned
    319
    evertyhing
    Metro Detroit
    i skimmed this thread...we charge 450 install plus bushings here at the shop. you need an alignment after for 125. if you wanted to lower it also that is a whole other job and requires other parts also. it all comes down to how much you love the car and are going to keep it as well as part cost and the end goal. some of the early r50s are going for 4K right now...you add bushings and lowering it and you have a 1500 bill (ish) to lover a 4K car. if it is mint ans your going to keep it makes sense, but if you going to sell it in a year..not as much. food for thought.
  17. iovecables
    iovecables Member
    May 25, 2014
    72
    Am getting some basic maintenance done on July 2nd. Will ask for a breakdown, but yes, that price included parts and labour.
  18. iovecables
    iovecables Member
    May 25, 2014
    72
    Happy to say the bushings - and everything else on the car is in VERY good condition. Only thing that needs addressing is the 3rd brake light is dead, and I'm down to 5/32 on the run flats.
    Let's see how long it takes the rozzers to notice....... :p
    Loving the CAI that Kevin's Auto Care installed for me.
      File size:
      69.6 KB
      171
