1st Gen R52 Cooper Convertible Convertible top rear weather seal - options
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Felixy69, Aug 4, 2016.
  1. Felixy69
    Felixy69 New Member
    Aug 2, 2016
    26
    Looking to replace my cracked convertible top to trunk weather seal
    This seems to be an expensive part, does anyone have a source to get this cheaper
    ECS I believe wants $400. USD for it which i think it's out the roof
    Any help would be great
  2. cooperjet
    cooperjet Well-Known Member
    Sep 4, 2009
    1,057
    197
    Pensacola, FL
    Eminiparts looks to have them for 172 each (left and right). Not sure what the shipping is. I might be getting mine from there as they seem to have the best price.
  3. Felixy69
    Felixy69 New Member
    Aug 2, 2016
    26
    Hi thx for ur help
    However, from the description , it only for one side for that price, therefore I will need to order two of those which equals close to $400
    Thanks anyways
  4. cooperjet
    Sep 4, 2009
    1,057
    197
    Pensacola, FL
    It is. That's why I said 172 each. 344 total which would be saving 56. And you would be buying from an MA sponsor.
    Sent from my iPad using Tapatalk
  5. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Don't skimp when replacing factory weather seal. OEM or bust!
  6. Whine not Walnuts
    Mar 14, 2017
    359
    253
    waitin for my check
    Fuquay Varina, NC
    I am a retired construction manager with 40 years of experience with millions of square feet of commercial construction. Also have a LEED AP. I know a little about keeping water vapor, water and air outside. The R52 top has what I call a rain bar around the portion of the top where it connects to the car. There is also a rubber gutter along the back where the top hits the trunk and a formed curved metal gutter along the two sides. The top is made so that water sheds off the roof and anything that does not run off on the metal sides, weeps down into the gutters. The gutters are sloped and either discharge out through the the trunk or to the front just behind the doors. Lift up the top at the trunk and you can see what I described.
    I trimmed off the rotted vinyl and applied a small bead of black silicone to cover up the stitches. If I was going to do concours, I would spend the money for the trim, but as the majority of people will have no idea that I trimmed the bad vinyl off, I will use the money for other work on the car.
    The picture with the chrome strips are Cowles # S37750 that is 1/2" wide. The second in black are the same trim that I painted black with a bumper type spray paint. You can choose, $40 or $400.
  7. BlimeyCabrio
    Great solution! Well done.
  8. Razone23
    Razone23 Active Member
    Nov 3, 2013
    175
    27
    technical support
    nothern CT
    I just ordered them, but that's a nice clean finish, would have done the same
  9. mhourican
    mhourican New Member
    Jun 25, 2017
    6
    I wish I had seen this post before I ordered the parts. I'm committed now.
