COOLING :: The New BIG Radiator
Discussion in 'Car Builds, Projects, Idea's Experiments' started by Nitrominis, Aug 5, 2009.
  1. Ryephile
    Ryephile New Member
    Apr 9, 2009
    299
    122
    Yes!
    Metro Detroit
    Ok let me see if I have this correct so far:
    *nice welded aluminum construction
    *75% more capacity mainly from bigger end tanks
    *stock mounting and A/C points [plug-n-play]
    While I agree with the extra insurance aspect of going with a larger radiator, just as important is ensuring the fan and shroud fit correctly to baffle and draw air with the same efficiency as stock. As such, I have 1 more fitment question:
    1) Uses stock fan shroud and baffles correctly to front panel?
    And finally; how much moolah are we talking here? Is there any chance someone in the U.S. can take over production and improve the value?
    Thanks,
    Ryan
  2. jiminni
    jiminni Well-Known Member
    262
    Ca.
    I guess the "people" in this forum are not "mad modders" :lol: Not sure what the point of your post is?
  3. Batrugger
    Batrugger New Member
    May 13, 2009
    463
    92
    Soldier
    Hesperia, Ca.
    #23 Batrugger, Aug 6, 2009
    I too was curious about the fan and the switch. MINI does not sell the fan and control switch separate from the radiator. Our switch failed on the way to AMVIV and i was able to break open the housing with the help of Danny and bypass it so it was always on, but to repair it, I had to buy a whole radiator and fan assembly. I know RMW is also selling a radiator replacement, but I can't find the post on NAM.
  4. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #24 Nitrominis, Aug 6, 2009
    Wrong....
    I asked you not to copy the text verbatim from the site and use it as a post.
    Look around, lots of link to lots of vendors both in the MINI realm and out.
    In fact my intention as I read your post was to mention the following...
    Zionsville Autosport has an all aluminum replacement made right here in the US. Indiana even.
    Arrgg....
  6. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #26 Nitrominis, Aug 6, 2009
  7. jiminni
    262
    Ca.
    Well I like your price of $500. If it in fact it is.
    More than Nathans link with a price of $875. :eek:
  8. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #28 Nitrominis, Aug 6, 2009
  9. jiminni
    262
    Ca.
    Yea, I just reread your first post and it seemed completely harmless? You also provided a link to a vendor here, that is also good. Oh and yea it's not red........yet :lol:
  10. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    #30 k-huevo, Aug 6, 2009
    Are you ready for aluminum radiator overload? Absolute Radiator Home Page
    The OE radiator removes from the front of the vehicle relatively easy, there’s nothing attached to it once the hoses are removed (heat exchanger and dryer excluded), so no switch to be concerned with. The fan’s attachment to the radiator support is another story. There’s plenty of room up front to use larger tubing like 1.25 inch.
    The OE radiator weighs very little; I doubt there would be a weight savings or gain for an all-aluminum one, I think it’s a non-issue in this case. If it were an old fashion steel and brass core it would be a major difference.
    I’ve seen one leak in the OE core, but a few leaks at the neck fittings on the end tanks. The fitting is a separate piece secured by a couple screws and an o-ring to seal. Times may have changed, but when I tried to repair one a few years ago the neck and o-ring was not available separately.
    I’m looking forward to seeing this radiator once Lynn gets it gussied up. After 32 days of +100F temps I’m excited about the prospect of an improved cooling system. It will require more than a radiator alone, but I believe in conjunction with other improved cooling components, it could go a long way to help control ignition intervention issues on days like these.
  11. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #31 Nitrominis, Aug 7, 2009
  12. Batrugger
    May 13, 2009
    463
    92
    Soldier
    Hesperia, Ca.
    Your fiance has good taste Lynn :Thumbsup: I too am surprised that this thread has been so serious :sosp:
  13. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #33 Nitrominis, Aug 7, 2009
  14. Deviant
    Deviant Banned
    Student
    Southern IL
    Who makes the 180 degree t-stat available on M7s site?
  15. jiminni
    262
    Ca.
    So Lynn forgot to ask you, do you know where to find the t-stat gasket by itself? Sucks when you have to buy a OEM t-stat just to get the gasket for the M7 element:incazzato:
  16. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #36 Nitrominis, Aug 7, 2009
  17. jiminni
    262
    Ca.
    Well considering the pile of t-stats on the floor in Steves shop, 750 would be doable :idea:........oh I also went to the Dodge dealer and checked with them on gaskets.....close but no cigar, the Neon is close but different :frown2:
  18. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #38 Nitrominis, Aug 7, 2009
  19. jiminni
    262
    Ca.
    #39 jiminni, Aug 7, 2009
  20. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #40 Nitrominis, Aug 11, 2009
