1st Gen R53 Cooper S Cooper S Max coolant Presure
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Xpress Motors, Aug 11, 2013.
  1. Xpress Motors
    Xpress Motors New Member
    Aug 11, 2013
    motor tech
    Torquay
    R53 Cooper S 2002 single OHC coolant presure Fault. after running engine for a few minuets the cooling system creates a very high pressure, But the temp gauge registers in middle i.e normal temp does any one have any ideas engine running smoth except on start up ja bit lumpy. Could it be head gasket????
    Maybe check your radiator cap.
  3. Xpress Motors
    Aug 11, 2013
    motor tech
    Torquay
    pressure
    Radiator cap ok. cap venting at extreme presure.
  4. Dave.0
    Could be the sign of the water pump or T-stat on its way out.
    I would not trust the gauge, it only shows, cold, normalish and overheating. I'd connect something that gives you an actual temp read out to see if it getting to hot or not.
    Possible causes are a thermostat not fully opening. When was the last time that was checked or changed. Has the cooling system been flushed recently, there could be a blockage from something being dislodged.
  6. minsanity
    minsanity Well-Known Member
    Sep 11, 2009
    581
    352
    +1 on the above. Or the cooling fan is cooked. Stock cap is just rated 16psi. Normal operating temps & pressures seldom vent thru the cap.
  7. Xpress Motors
    Aug 11, 2013
    motor tech
    Torquay
    gasket
    Thanks for your replies in the process of changing the head gasket and thermostat will up date you later. :arf:
