Way Motor Works has one of the coolest and most cost effective diagnosis tools available. This Easy Diag tool is a simple bluetooth plug that connects to the OBDII connector. After you hook it up you connect via bluetooth to either an Apple product Ipod, Ipad, Iphone or Android device. Then you simply can read codes, clear codes, or read data streams. But not just in the DME, you can also do ABS, Airbag, Body modules, Heating, A/C, and more. After you get the tool you will have to go online and register it and download the app to use it. Then you will have to download the specific MINI software for $40. After that just start your diagnosis. There is NO LIMIT on the number of cars you can use it on. And you can download software to do diagnosis on any other make of car for an additional $40 per make of car. Making this the most cost effective tool to read and clear codes. We've found using it from the Ipad to be really simple. Here is a screenshot of all the modules you can connect to on the R50 R52 R53 MINIs. And this is a screenshot of an R56 showing all the modules you can use it on Start your Diagnosis today with the Easy Diag Tool, and save the expensive dealer cost to clear a simple fault.
