2nd Gen R56 Cooper S Creaking noise from front of car
Discussion in '2nd Generation: 2007+ R55 through R61' started by grodenglaive, Sep 28, 2011.
  1. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    A creaking noise has developed on the driver's side when I pull away from a stop or lift off the gas suddenly. It's only noticeable when moving slowly in 1st gear. Going over bumps doesn't seem to cause the noise, just starting and stopping. It's similar to when I had to replace a bad transmission mount, but more of a creak than a clunk. I'm thinking engine mount or maybe a cv joint?
  2. jiminni
    jiminni Well-Known Member
    262
    Ca.
    Edit......this is a 2nd gen. thread.
  3. CHKMINI
    Loose wheel lugs?
  4. grodenglaive
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    nope, first thing I checked:Thumbsup:
  5. Metalman
    If your CV boot is torn, look for grease being thrown out. Maybe the joint is running dry or starting to get there.
  6. Metalman
    Have you gone over to any of those polyflex bushings? If they need to be regreased and are running dry, they will make a squeaking noise.
  7. grodenglaive
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    actually I have the powerflex control arm bushings. It would be nice if that was all it was. :fingerscrossed:
    I think I better take it in tomorrow to get it checked - today sounds worse than yesterday...
  8. lotsie
    stagehand/part time detailer
    Right here
    I had a creaking, clunking sound coming from front passenger side. Only heard it going slow in first, turned out to be a bad axle.
    Mark
  9. grodenglaive
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    Good news, sort of: the garage cannot find any mechanical problems (drivetrain, suspension, transmission mounts). They were quite thorough - at one point the service manager actually drove around the parking lot with his mechanic lying across his lap with his head hanging out the door to listen. They can't positively nail down the source of the creaking, but they figure it is likely the polyflex bushings.
    I'm not going to pay to have those redone at this time though - it was a big job getting them installed. I can live with a bit of creaking, now that they assured me it's is nothing dangerous.
    Thanks for the suggestions:)
    Where do you have the poly bushings installed?
  11. grodenglaive
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
