I had my Cusco LSD installed along with the Clutch Masters Fx300 Kevlar clutch + flywheel done by Helix in Philly a couple weeks ago. The parts now have just over 1000 miles on them and the clutch has been properly bedded in as per directions. The car is much more fun through corners and on / off ramps now, it is much easier to steer using the throttle, you can feel the car transition as you feather the throttle through curves. It is great to floor it in 2nd through an on / off ramp and feel the car really bite down and pull through the ramp. The Cusco also locks up on decel and has helpes make the car much more sure footed on heavy braking on bumpy road surfaces. The clutch is buttery smooth and very quick on the take up, it engages firmly, to the point that when running through the gears hard, I can chirp 1st, 2nd , 3rd very easily however the DCS will engage and bog the car - this never happened with the stock clutch. Problem solved but turning hte DSC off - lol. The lightened flywheel really livens up the motors response rev matching is much easier and the car doesn't feel as bogged down off idle as it used to. All in all a great combo. The Cusco clutch was sourced from RMW, the Clutchmasters clutch / flywheel were sourced through Helix.
Congrats on the install! Looking at your engine mods, the FX300 was a bit of overkill unless you have some big future plans. I had that exact clutch on my turbo project R53 and even with 260wLb/Ft it clamped like nobody's business. Good to hear the Cusco diff works nicely, especially good to hear it helps in straight-line braking. You'll just have to get used to implementing turning off DSC in your pre-flight checklist!
Considering the FX200 was the same price as the FX300 - I went with the 300 - primarily because of the future upgrade path.
Cool. Whenever you're ready for twincharge/twinscrew/turbo-only/huge nitrous you'll be good-to-go. :ihih:
waiting to test drive the mendra mobile!!!!:cornut: njmsp thunderbolt course oct 31st and/or nov 1st? i'll go to whichever you can make:yesnod: PDA Driving School
So is it the 1.5 way or 2 way LSD? It didn't add any under-steer or dampen the nimbleness? What is the weight of the clutchmasters flywheel? No chattering with any of this?
