1st Gen R50 Cooper CVT Transmission fluid change
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by MyklMacD, Sep 28, 2014.
  1. MyklMacD
    MyklMacD New Member
    Aug 26, 2013
    120
    Recovery Specialist @ WRC Telecare WRC
    Salem, OR
    I own a 2002 R50 Mini cooper w/ Automatic CVT. My MINI has 140k miles and I'm unsure if the previous owner every had the transmission fluid changed. So my question is... where should I take my MINI to have it serviced? Only reason I'm worried about taking it to a local shop is due to the CVT and if the shop has experience working on them. I understand that I might be worried for nothing but Id rather be on the safe side and ask someone who knows. I called my local MINI dealership and they want 280 to change it. Any thoughts from an experience MINI owner?
  2. M1N1
    M1N1 Well-Known Member
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    Take a look in the library. There is a "how to" on changing the fluid in a 6 speed that may give you some pointers.
  3. Ernesto
    Ernesto Club Coordinator
    May 16, 2009
    642
    652
    Oracle DBA
    Skokie Ill
    I've had my 2003 Cooper CVT fluid flushed twice over the past 6 years at a non-MINI shop that had an ex-MINI tech working there.. Cost was about the same as your quote.
  4. MyklMacD
    MyklMacD New Member
    Aug 26, 2013
    120
    Salem, OR
    Thanks for the replies, I'll check some local shops and get some quotes, I was mainly worried about whether or not the CVT was similar to other transmissions or if i need to go to someone who has experience.
    Thanks time for a :beer
    :mtrn:
