2nd Gen R56 Cooper S Damn Ticking
Discussion in '2nd Generation: 2007+ R55 through R61' started by Apok, May 13, 2015.
  1. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Its back in my 2010 Cooper S. Last time it was the vacuum pump, I replaced that late last summer. And now it seems louder! I need to take a few mins and locate for sure, but this time I don't think its the pump. Sounds like it might be in the head, but I dunno. Ugh, I hate not knowing what it is and if it is a major problem or just an annoying sound.
  2. Zapski
    Like a regular ticking, or related to engine revs? Heard on road or at idle?
  3. Jason Montague
    :cornut: No help here. BUMP:Thumbsup:
  4. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    More info needed. If it's from your engine bay, you can use a long prybar or equivalent and use it as a stethoscope by placing it on various (non moving) parts of the engine. That'll give you a general location of the ticking. Let us know...
  5. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    At idle is the only time I can hear it. Yup, I'll be taking the long screwdriver to it tonight to see if I can figure out where exactly its coming from. Seems like sometimes its a little quieter than others.
  6. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Ok, so using the old giant screw driver, an hand me down from grandpa, I did a little doctoring. Though the vacuum pump is ticking, not the same way it was before I replaced it. It almost sounds as if the nose is coming from the center of the valve cover. Also noticed that I'm down a little over a half quart of oil. So maybe its just the valves. I'll get some oil this evening and top off. Perhaps that will do the trick. I will note, that the ticking/tapping sound was not as prominent last night. I even let the car run for awhile to warm up to see if there was a difference.
  7. Eric@Helix
    1,257
    Shepherd
    Philadelphia
    Either the valves or the chain/tensioner/guides. I would do a complete oil change, with filter for starters and see what happens.
  8. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Yeah, thats on the block when I do brakes.
  9. Dave.0
    When you drain your oil look for your lost watch. :lol:
    Must be a Timex, "takes a licking & keep on ticking".
  11. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    But I haven't worn a watch in probably 10 years, lol.
  12. 00Mini
    2,227
    Wow ! When you find it will be a really special moment !! :Thumbsup:
