DCT P0597
Discussion in 'Starting Line - New Member Introductions' started by irdon, Jan 15, 2015.
  1. irdon
    irdon New Member
    Jan 15, 2015
    Hello I'm new to the form and new to minis this morning I had a hard time starting my 2011 club men I hope that my scanner and pulled the code DCT PO 597 thermostat heater control circuit open can anybody help me with this.
  2. 00Mini
    2,228
    Welcome to M/A !! I'm sorry but I cannot be of help on your problem but others will along this morning who will be able to help you.
  3. MCS02
    6,278
    Welcome to MA! One of the Gen 2 guys should be along soon to help.
  4. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    Welcome to the coolest MINI fourm!
    If you are low or out of coolant the car will throw that code. I would start there and check for leaks with the water pump and thermostat. If no low coolant, there could be an internal failure in your thermostat housing. These t-stats are a complete housing with the temp sensor included. The unit would most likely need to be replaced.
    Welcome to M/A
    I've seen a picture of the thermostat housing looks like a Jarvik 7 artificial heart to me.
  6. wmwny
    4,048
    2,246
    Welcome to M/A!
  7. irdon
    irdon New Member
    Jan 15, 2015
    Thank all of you for the warm welcome .
    the coolant is the proper level and I see no leaks anywhere is there a way to perform test on the electronics in the thermostat housing
  8. irdon
    irdon New Member
    Jan 15, 2015
    By the way the radiator fan and comes on as soon as you start it and stays on for 10 or 15 minutes after you turn it off.
  9. Dave.0
    Welcome to M\A the FUN MINI site. :Thumbsup:
