1st Gen R53 Cooper S Digital Gauges
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Sleek Motoring, Jan 14, 2015.
  1. Sleek Motoring
    Sleek Motoring Local Shop Owner
    Dec 7, 2014
    249
    143
    Mini repair shop owner
    Colorado Springs, Colorado
    I have a hotrod diesel truck, I have a set of digital gauges that plug into the OBDII port and display almost every engine parameter(transmission fluid temp,engine oil temp,gear, MPH,ect...). The only probe I installed was one for Exhaust Gas Temperature (EGT).
    The system I have is and Edge CTS insight. Does anyone know if they make a product for the mini cooper that would work in the same manner? I do not want to have a bunch of gauges going up the A-pillar or around the Tach/speedo.
    What are my options?
    Thanks!
  2. ScottinBend
    ScanguageII......or a good app for the phone.
  3. Spa2k
    Spa2k Well-Known Member
    May 9, 2013
    1,955
    975
    Iowa
    Dash Command app, plus a $12 Bluetooth transmitter that plugs into the OBD II port. This probably isn't as comprehensive a combination as you're looking for, though.
  4. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    I have a Scangauge II in my car.
    Not very fancy but it works with the benefit of letting me reset codes.
  5. Minidave
    4,592
    I use my Garmin....
  6. Sleek Motoring
    Dec 7, 2014
    249
    143
    What parameters will this display?
    What model Garmin?
  7. ScottinBend
    Check out both Garmin.com and the ScangaugeII website.......
  8. Sleek Motoring
    Dec 7, 2014
    249
    143
    Thanks for sharing the Scangauge II. What engine parameters will this display on an R53?
  9. Dave.0
  10. Sleek Motoring
    Dec 7, 2014
    249
    143
  11. Stefanie
    Stefanie Well-Known Member
    May 8, 2014
    545
    804
    Sacramento, CA
    #11 Stefanie, Jan 17, 2015
  12. 00Mini
    2,227
    The link is not working.
  13. ScottinBend
  14. Stefanie
    May 8, 2014
    545
    804
    Sacramento, CA
    Hah, thanks...I suck. Fixed it!
  15. Sleek Motoring
    Dec 7, 2014
    249
    143
    So I decided on some Cravenspeed boost and oil pressure gauges along with the Scangauge II. Should be a solid setup.
    Thanks for all the feedback!
  16. Kellen@Craven
    Kellen@Craven New Member
    36
    Talking about Minis and stuff
    Portland, OR
    I am going to have to agree, nice choice.
  17. beken
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    Sorry...I wasn't looking....
    I've got mine set to display Boost, Water Temp, Intake Air temp, and Ignition timing.
    Others displays you can set on the Scangauge include :
    Battery Voltage
    Engine Load
    Miles/Liters per gallon
    Fuel pressure
    Fuel system loop
    Throttle position
    RPM
    MPH
    Manifold Absolute Pressure
    plus you can program your own gauges using xcode and reading whatever you can get from your OBDII port.
    Boost is based on the MAP (Manifold Absolute Pressure) gauge.
  18. Sleek Motoring
    Dec 7, 2014
    249
    143
    What will it take to get an oil temp gauge?
  19. TheModFather
    Adding a sensor, either the factory plug sensor, or drill and tap the filter housing.
  20. Sleek Motoring
    Dec 7, 2014
    249
    143
    What is that?
