Does it go down with the toggle? If it does, can you see if the passenger side operates faster than the driver's (both up and down)? I have a similar thing happening with my passenger window.
Mark, try this:
In the R53 MINI, to reset the windows, you hold up the window toggle switch for 5-10 seconds to re-initialize them in the computer.
If the window still does not work, you can try taking the door panel off and make sure the plug is still attached to the regulator. Beyond that, it might be a bad regulator.
Steve -
goaljnky, try what mielnicki said. If this doesn't work try holding down on the toggle(if the window is stuck closed) and with the ignition on pound on the door above the speaker. This is the "Fonzie" method. This knocks the dust and dirt between the armature and brushes loose causing contact once more. It worked for me. Eventually I'll have to take the motor apart and clean it. Hope this helps. :mad2:. BTW, my windows have never traveled at the same speed.
Mark -
Can anyone point me to a how-to for door panel removal? I just might poke around in there myself.
goaljnky, go to "motoring/underground" web site and search the same question. I went there and searched "window will not go down" and the answers go back several years, including pictures and directions. :cornut:.
Good luck, Mark :aureola: -
MINI COOPER :: North American Motoring - Window failure fix free!
here is a write up on fixing it -
danglero Club Coordinator
Last time I had window issues, I went to mini, and they re-installed the software. Yes, sure that also worked. Most of my day was sucked up through the process. I don't go down to the dealer much for service anymore. I'll go there for the free brakes, even though their brakes kick up an insane amount of brake dust. Oh, and wiper blades!!!
