Engine Drivetrain 1st Gen Cooper ECU tuning
Discussion in 'Tuning and Performance' started by daviday, Mar 27, 2014.
  1. daviday
    daviday Active Member
    Jan 15, 2014
    140
    25
    Did a search and got no hits. Found it odd. Ecu may be too short for the search box though.
    Anywho there aren't many new topics in this area so figured id make one. :)
    Rather than bore you with the back story and reason for the post I'm curious if anyone has done any tuning to the factory ECU? What they did? How they did it? Etc...
    I'm VERY sensitive/aware of changes in my car as I drive a lot and feel as if I'm noticing a few changes after regular maintenance.
    What year MINI do you have ?
    Look up RMW a.k.a. Revolution Mini Works. Jan is the owner / ECU tuner. :Thumbsup:
  3. daviday
    Jan 15, 2014
    140
    25
    03. Thanks man.
  4. MCS02
    6,328
    Don't worry about doing searches here. It never works anyway. We will answer the question even if it's been asked before and never tell you to do a search. :Thumbsup:
  5. ZippyNH
    Sounds like a custom tune would make you happy....
    RMW did mine...
    More power, smoother running than new, and more MPG....tough to beat...
    Also had the DSC tweaked to make it less obnoxious..... And gas pedal made more sensetive....made the $$ I paid a great deal.
  6. Dave.0
  7. daviday
    Jan 15, 2014
    140
    25
    Okay the car just died.... Hahha. How do I reset the Ecu? Ie: is there a back up power source?
  8. Dave.0
    Replace the cars battery.
  9. wmwny
    4,040
    2,242
    I had Way [waymotorworks.com] do mine and am really happy with them. One is on an '06 MCSa and the other is on an '03 Cooper cvt. I am considering having him do one on my wife's '06 MCSa, too
  10. wmwny
    4,040
    2,242
    #10 wmwny, Mar 28, 2014
    oops
  11. Dave.0
    Way's (WMW) canned tunes are not custom tunes they are just standard JCW flashes and some of them are really just copies of Jan's tunes from when they had a fallout long ago. (Pre gen 2)
    Way is not a custom tuner period, sorry but it's the truth.
  12. daviday
    Jan 15, 2014
    140
    25
    Replace the cars battery? The battery is fine, I have cables also. In any event the radio presets are still there...
  13. Dave.0
    What's the car doing? Give a little more to go on.....
    Year
    Model
    Mods
    Milage
  14. daviday
    Jan 15, 2014
    140
    25
    Sorry, 03 r50 90k miles bone stock.
  15. Dave.0
    Ok when you say it is dead what do you mean?
    Won't start "click" Or just keeps turning over and over?
    Have you checked all the fuses including the ones under the hood?
    Check plug wires and coil connections?
  16. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
    Looks like we have been invited to go on a fishing trip. :rolleyes:
    daviday, Welcome to the friendliest MINI site on the interweb. We will be happy to help you if we can, but you need to be prepared to provide actual information that might help us help you.
    So, besides the age and mileage, what else can you tell us? What are the symptoms? What might you have changed just before this? Noises, smells, etc?
  17. daviday
    Jan 15, 2014
    140
    25
    I recently had the belt and tensioner changed as well.
  18. daviday
    Jan 15, 2014
    140
    25
    Thank you guys, my data connection lags sometimes.
    The battery has plenty of power. The starter wants to turn it over. It just won't. No smell, no smoke, no odd noises. I started the car and drove a few blocks and turned it off.
    Now I'm here.
  19. Nathan
    In the main fuse block under the hood there is one really big one that sometimes will loosen a bit. Check that all of them in there are set in place firmly.
  20. daviday
    Jan 15, 2014
    140
    25
    Left the car. I'll check it in the am. I needed a stiff one after troubleshooting.
