Engine Drivetrain 1st Gen Cooper Engine Bay Bling
Discussion in 'Tuning and Performance' started by agranger, Feb 4, 2011.
  1. CHKMINI
    ..."leave the bling for the Escolade's" :p
  2. Mr. Jim
    Werd :cornut:
    Black out & carbon fiber are the new improved bling....
    I really respect folks who can make their engine bays sparkle. :Thumbsup:
  4. agranger
    Ok... So I was helping a friend with a brake job today and applied a few coats of plastidip between wheels.
    Before:
    AFTER:
  5. agranger
    More fun with paint.
  6. agranger
    Installed
    Looks great...now the MINI on the valve cover
  8. Mr. Jim
    When I looked at that picture I thought the same thing.
  9. agranger
    LOL. I had the same thought, but that part sees much more heat than the others.
    I think I saw some tinting spray... Like transparent paint. I wonder if it would hold up to the heat?
  10. Metalman
    7,700
    Soooo.....
    Are you going to have a tent set up in the Fontana parking lot???:Thumbsup:
  11. Firebro17
    OK I give up... What's the trick??? It's gotta be more than a steady hand...:beer
  12. agranger
    The trick is to use a paint pen... Like a fat Sharpie (fiber/felt tip), but with an opaque paint instead of transparent ink... The kind like the metallic markers from a few years ago where you depress the tip to recoat with paint. The raised letters make it surprisingly easy to get good results, though I recommend using a water-based paint and having a good supply of q-tips at the ready to fix your mistakes.
  13. CheckersSD
    CheckersSD New Member
    Mar 3, 2011
    129
    6
    Full time student @ UCSD majoring in PoliSci, and
    San Diego, CA
    I love the way it turned out. Something I would love to try myself.
  14. Firebro17
    Very Cool! I've done stuff like that before with good results and I kinda thought maybe that's what you may be doing. Thanks for the info and now I'm off to be a copy-cat.....:beer::Thumbsup: Thanks.
  15. agranger
    I checked last night... After a 45 min highway drive and 30 min to cool, that valve cover logo / metal plate was too hot to touch for more than a few seconds. Vinyl won't work and regular paint (like a transparent tint spray) may have a problem as well. A high-temp paint may work, but reproducing the logo in paint may be more than I'm ready for.
  16. Batrugger
    Batrugger New Member
    May 13, 2009
    463
    92
    Soldier
    Hesperia, Ca.
    FYI, if you remove the MINI plate from the valve cover, it says "1.6L 16 Valve" under it in raised letters that could probably be easily painted with red brake caliper paint.
  17. agranger
    I finished the inner Intercooler scoop (an aftermarket piece that comes with the big Intercooler). It was scratched and overly worn from the previous owner... Time for a clean-up
  18. agranger
    I've got a new custom solution you will like for this issue... It is in the mail!
    :popcorn:
  20. Mr. Jim
    :popcorn::beer:popcorn:
