1st Gen R53 Cooper S Engine Died - Now it won't start!
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by MiniMadMike, Aug 3, 2015.
  1. ScottinBend
    I would also double or even triple check those compression numbers........
  2. myles2go
    myles2go Active Member
    May 7, 2012
    589
    223
    collecting a paycheck
    WI
    I'm not sure it is the timing chain. That would affect all cylinders equally.
  3. Minidave
    No compression.......who suggested that was the problem????? :D
    I think it done blowed up.
  4. MCS02
    Good job Minidave. I thought you were barking up the wrong tree. Maybe Nathan should start an advice of the month award.:D
  5. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    Blowing 3 cylinders at the same time with no codes?????? I would think that the dash lights would look like Christmas trees...
  6. MiniMadMike
    MiniMadMike New Member
    Aug 3, 2015
    9
    6
    No dash lights when it broke down whatsoever :(
    Will re-check the compression just incase i messed something up the first time, and will check the timing as its a quick job. If I get no joy the head is coming off :'(
    I'll report back at the weekend. Thanks for all of your help guys!
  7. Minidave
    I'm not suggesting Mike isn't telling us the truth, but when he pulls the head off and finds carnage inside......well, every time someone tells me the car was just idling and died and I see huge destruction inside or a well ventilated block, it makes me wonder whether seconds before he was foot to the floor in the lower gears or missed a shift........just before it quit! :biggrin5:
    BTW, doesn't the engine sound significantly different when it cranks over? Absent compression on three cylinders, it should........
    Can't wait to see some photos, Mike! :Thumbsup:
    Oh the old money shift. BANG $$$$
  9. MiniMadMike
    Aug 3, 2015
    9
    6
    Hello Team,
    Well I found the problem, I'll let the pics do the talking...
    image.jpg1_zps7ngjpxsd.jpg image.jpg2_zpsknr2stmo.jpg image.jpg3_zpsobwtaidl.jpg image.jpg4_zpskws91jkg.jpg
    Yep! The Camshaft snapped. Looks like it's due to a manufacturing issue with the casting of the shaft itself - the split that runs into the centre of the material lines up exactly with the casting line that runs along the length of the shaft.
    This camshaft is only 5k miles old - it was replaced with the cylinder head 5k miles ago (due to the ejection of a spark plug - unrelated issue).
    Definitely one for the x-files, looks like I've been unlucky.
    Thanks for all the advice guys.
  10. Systemlord
    Systemlord New Member
    Mar 28, 2013
    311
    67
    I never would have guessed a snapped camshaft, I believe you might not have any other issues resulting from the split-up, the valves probably just closed up quick like. That cam definitely has a serious casting flaw!
  11. MiniMadMike
    Aug 3, 2015
    9
    6
    Yeah I've had an endoscope down the bores and we'v not had any contact or anything like that. Can't see any other damage so as you say the valve probs closed up and that was that. Think I've been lucky in that respect. But yeah pretty crazy issue!
  12. MCS02
    Glad you found it!
  13. vetsvette
    Not something you see every day, that's for sure. I believe I would be having a talk with whoever supplied that camshaft!
  14. Minidave
    Best possible outcome from a worst case scenario!
    You'll have it up and running again in no time - good job.....:Thumbsup:
  15. MiniMadMike
    Aug 3, 2015
    9
    6
    Cheers guys!!
  16. Nathan
    Pop over to the plant in Oxford, cam in hand, ask nicely for a new one. :ihih:
  17. Systemlord
    Mar 28, 2013
    311
    67
    If it's a reputable shop they should be happy to supply you with a new replacement camshaft since the casting flaw is easy to see and since I'm assuming they installed the camshaft they should install it as well. I'm sure the shop will be happy for the simply fact that your motor wasn't damaged by their rebuild work. I would also contact the manufacture and let them know about the casting flaw, that way if there are other's like you out there that start splitting cams in half at least they will know.
    Let us know what happens.
  18. Minidave
    I'm not sure that's aftermarket stuff, he said he replaced the old head cause a spark plug blew out and ruined the threads (I assume) so it could just be a used factory stock head.
    Mike?
  19. MiniMadMike
    Aug 3, 2015
    9
    6
    Morning guys,
    Yes it was a (new) factory standard Cooper S head with valve train. I've now had it agreed with the supplier (not BMW) that they'll give me a replacement camshaft free of charge so all is well.
  20. Minidave
    You'll be back on the road in no time, hope the valves weren't damaged - I know you said you had a borescope in it and didn't see anything - hope that's right!
