1st Gen R53 Cooper S Engine overheating, spewing coolant
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Gizmo, Mar 2, 2013.
  1. Jason Montague
    :wink::wink::wink: To paraphrase 'The Old Sage', "Walnut them, they'll buff out.":lol::lol::lol:
    I'd suggest changing your oil. It is quite possible that carb cleaner & other gunk has made its way into the sump.
    As far as those infectors go, those nice supple seals turn into hard plastic with age.
  3. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    I already changed the oil and coolant.
    Figured some of the chemicals would find their way into the supplies.
  4. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    #44 Gizmo, Mar 15, 2013
    A friend gave me his injectors since the new ones won't be here until Monday, they were removed at an early mileage for JCW ones.
    Got everything back together, cranked the engine but wouldn't start again. Pulled the plugs, 1 is dry, 2-4 are wet with a black/brown liquid (oil possibly).
    Shine a light into the spark plug tubes, cylinder 1 looks good, 2/4 are wet with a black liquid and possibly some deposits I can see parts of the piston head so it isn't completely covered in the liquid.
    I don't know what to do, I'm worried I have to take everything apart again to see what is causing this.
    Edit: also checked the spark and all four are sparking fine.
  5. Mr. Jim
    Are you getting voltage to the injectors?
    Did you have JCW injectors before?
  6. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    I have stock injector now, I'm saying my friend replaced his with JCWs.
    Cylinder 4 has a lot of crap in the cylinder, the others don't look bad. I don't think it is oil because I just changed it and intue dipstick the oil is a clear and light brown.
    I hooked up the pressure gauge to the cylinders and now I have no compression in any of them. I'm going to take the valve cover off and inspect.
  7. Jason Montague
    :cornut: GOOD LUCK! Prayer sent.:Thumbsup:
  8. Thumper460
    Thumper460 Active Member
    May 26, 2009
    559
    94
    United States Navy ..Retired
    NO Compression?? Camshaft would kill compression in all chambers, also the lack of oil on the rings ( though usually NOT all 4 cylinders).
    WHEN you put the head back on was the camshaft gear installed right where it came out?? DID you turn the engine over with the head off and MOVE the cam chain ??
    Keep in mind that the cam phase being out can cause piston to valve interface issues.. ( like Bend the valves) so be carefull.
    Let us know on the compression and camshaft.. cool??
    Thumper
  9. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    It's not going to be a good day...
    Took the valve cover off, noticed the timing chain sprocket was not straight...
    Unbolted the nut and here you go.
    :mad::mad::mad::mad:
    The 'key' on the camshaft stripped part of the metal on the timing chain sprocket. So now the timing is definitely off, even if I put the cam in the same position as the key hole on the sprocket, how would I know if it is even correct?
    So maybe the crap in the cylinder isn't the issue, this is why the engine isn't starting.
    This is not good.
  10. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    Thumper, the engine chain wasn't moved when the head was off.
  11. Thumper460
    May 26, 2009
    559
    94
    STOP!! Dont turn the engine over any more.. cool??
    Mark the chain and cam gear... remove the Cam!! All the valves now will be closed ( hopfully) Apply air to the cylinders and see if the air leaks out past the valves!! If they do.. then the head has bent valves!! IF they dont, then you passed a bullet!!
    Check to make sure the cam chain and the cam gear are friendly ( where they are SUSPOSED to be on alighn ment. IF they are not, then make them so... Remove the dampner/ the Belt tensionar/ and the timing cover... alighn the 2 crank gear and the 2 chain marks up.. do the same to the camgear and cam ( per manual) and start all over again.
    Let me know...
    Thumper
  12. Thumper460
    May 26, 2009
    559
    94
    Fantastic...!!
    I would remove the cam and do the air test!! Make sure the cylinders hold pressure. Squirt just a teaspoon of oil in each cylinder to help seal the rings... test for pressure. then install the cam with a new timing gear.
    When the damaged cam gear slipped, it still could have damaged the valves. So now eliminate that issue. Cool??
    SUX, Yes??
    Thumper
  13. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    I just ordered a new camshaft gear, it's not good when the parts guy knows your name.
    Will be ready for pickup tomorrow morning.
    I'll remove the cam now.
  14. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    Camshaft is removed...how do I go about pressure testing/putting air into it though?
  15. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    Wait, I got it. I'll use the compression tester adapter for the spark plug thread
  16. Thumper460
    May 26, 2009
    559
    94
    cool...
    Thumper
  17. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    So I put 35 PSI in each cylinder with the adapter...
    Cyl. 4 - good, Cyl. 3 - good, Cyl. 2 - good, Cyl. 1 - I hear a leak.
    Go up to the engine, don't hear anything but I still hear a leak. It was just the quick disconnect adapter on the compressor hose that I heard the leak from LOL.
    All four cylinders tested fine.
  18. Thumper460
    May 26, 2009
    559
    94
    Cool... you should be fine. I pull the ECU relay, and then after putting it all back.. I turn the engine over to make sure all is good, also it pumps up the lifters and oil pressure. THEN install the relay and Rock!!
    Have fun....
    Thumper
  19. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    this is very exciting, I hope it has a happy ending:)
  20. 1momini
    1momini New Member
    Feb 19, 2013
    102
    46
    mechanical contractor
    Arkansas
    Yes yes enjoying this post hope it all works out.
