Way Motor Works has the most cost effective solution to reduce engine rock in your MINI. With our FWD MINIs we find torque steer to be an issue. This compounded with the engine rocking back and forth as you accelerate and decelerate. The engine rocking also stretches on the shift cables and can make shifting even harder when your getting on the power. WMW has found installing bushings in the gaps of the stock engine mounts the most cost effective way to reduce the engine rock without making them so solid the whole car shakes apart. This is a no brainer first mod for any MINI owner, and simple enough you can do it yourself. NM Torque Arm Bushing for R55 R56 R57 R58 R59 Cooper and Cooper S Also avail for R60 Countryman and R61 Paceman 2WD and then avail for ALL 4 Countryman and Paceman too. If you have a Gen 1 2002-2006 R50 R52 R53 Cooper or S we have the Powerflex equivalent.
