2nd Gen R55 Clubman Engine Stutter
Discussion in '2nd Generation: 2007+ R55 through R61' started by MOB, Nov 24, 2016.
  1. MOB
    MOB New Member
    Nov 1, 2016
    I have a 2008 R55 with 106k miles. Only MOD being a K&N CAI to replace the factory pipe which was cracked because the previous owner tightened the clamp to tight and I wanted to replace it with an aluminum pipe.
    The car has no CEL but when cruising around 2000 rpm, but when I apply a little throttle to the point where the car doesn't downshift or the rpm's don't climb but the CAI starts sucking massive air the car will stutter usually about 3 times before going back to normal. Doesn't seem to be an issue if I give it enough gas to make the motor revs up as well. Doesn't do it all the time but I can replicate the issue if I try.
    My only guess is that the MAF is going bad and the ECU can't apply the correct air to fuel ratio.
    I appreciate any advice. Happy Turkey Day
    Sent from my Pixel using Tapatalk
    Carbon build up, walnut blasting needed if it has not been done in 50K. Also only run 91 octane above if you can find it.
  3. MOB
    MOB New Member
    Nov 1, 2016
    Okay thanks for the advice. I have only run 91 since I bought the car 40k miles ago.
  4. Metalman
    If it is the "S", then David.0 is most likely correct with carbon buildup on the intake valves.... They can be cleaned with the walnut blast that doesn't damage the valves and it usually gets done around 50K or so.... Approximately $300.00 to have done...
    If your MINI is not an "S", then it's not carbon buildup but something else...
  5. 00Mini
    2,263
    Might be helpful to check for some diagnostic engine codes.
  6. cct1
    Y-y-y-es. th-th-th-th-the st-st-stutter is m-m-m-most l-l-l-likely c-c-c-carbon b-b-buildup.
  7. ILive
    ILive New Member
    Nov 12, 2016
    Mine stutters also lately at 3rd or 4th at around high rpm, recently cleaned the sensors but I guess didn't change anything
    Sent from my QTAQZ3 using Tapatalk
