Engine Exhaust - What are you running?
Discussion in 'Tuning and Performance' started by Sully, Mar 28, 2019.
  1. Dave.0
  2. minirab
    Deleted the resonator, cheap and sounds like it should.
  3. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    So in talking with a few folks, it appears the Milltek exhaust doesn't fit well on the GP2. Also putting it on and getting all the pieces correct is also an issue. Anyone have any experience with that?
    One person recommended this the Akrapovic.. its a bit more expensive though. https://www.outmotoring.com/akrapovic-evolution-exhaust-r56-8-s.html
  4. MCS02
    Nice looking system
  5. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Should be for that kind of cost. :)
  6. Dave.0
    Have you asked Chad? I am sure his guys know how to fit a Milltek correctly without any issues. Some times DIY’s do not give the best advice.
  7. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Yup talked with Chad and a few other shops. Milltek can be more cumbersome to mount and get fitted correctly. That said, the Akrapovic is also very nice, potentially a little lighter (need to confirm that) and the fit is spot on. It also comes with a set of very nice carbon fiber tips. Still working through the details between both of those.
    Now I'm thinking about my downpipe. I was thinking about having it ceramic coated. I do that when I put on headers for normally aspirated cars. It appears this is also pretty common and outside of just helping keep the engine bay cooler, it also increases the velocity high.
    Anyone here done that?
  8. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    So been thinking about this more and doing more research about volume and velocity. What Turbo are you running and are you running a 3" downpipe or just a 3" exhaust?
  9. oldbrokenwind
    oldbrokenwind Active Member
    Oct 18, 2012
    196
    107
    Northern NV
    GTX2860R with a catless downpipe from TurboKits who sold me the turbo in a kit. Married it to an Alta 3" exhaust system then added another resonator to keep noises to a minimum. After lotsa mods, this turbo is too small, so looking at another upgrade --- someday.
  10. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
  11. oldbrokenwind
    Oct 18, 2012
    196
    107
    Northern NV
    Sure looks like it --- 3" all the way. Back in 2011, Turbo Kits got their materials from ATP Turbo. Also, my buy was before the GTX ~ it included a GT28RS. Current version is a much better turbo. Note --- their claim of 450HP must be in BHP, not WHP. Even the GTX can't provide the boost continuously thru the RPM max. Garrett catalog also limits HP claims to about 350 or so.
    Another thought --- when I had my extra resonator added, the shop mentioned they could have done the complete exhaust system for a lot less money than buying a bunch of fancy chromed pipes. Would have fit a lot better too. FYI --- there's a bracket / brace near the muffler that helps contain the system if supporting mechanism fails. This bracket / brace will not accommodate a 3" pipe and must be removed or have spacers added to longer bolts. Hasn't caused any problems in the 8+ years I've been without it. Actually easier to drop the exhaust when pulling the engine. Anyhow, you should consider letting a good, local, muffler shop build a system for you. If you're planning on a 300+WHP build, you should go with the least resistance muffler, and forget what it sounds like --- I can assure you it will be nice and deep sounding.
    • Like Like x 2
    • Informative Informative x 2
  12. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Good info.. I appreciate it.
    I was doing some more research. Based on the current Turbo I have in the car (Franken Turbo), it doesn't push nearly as much air. I also confirmed I already have a 2.5" catless downpipe.
  13. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    00B04902-7F97-42BB-8C83-98F4BC922A6C.jpeg What’s in the box? :Whistling:
  14. wmwny
    4,040
    2,242
  15. MCS02
    looks like one box is a AEM intake. I can't wait to see how you like it!
  16. 00Mini
    I agree on the AEM intake.
  17. 00Mini
    And a strut brace.
  18. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Yup - AEM intake, strut brace.. and a very 16.4 pound exhaust. Trying to get the baseline Dyno run scheduled next week before I swap it all out. :)
  19. MCS02
    That’s great. Can’t wait to see the numbers!
  20. Dave.0
    Time to post unboxed pictures......
    • Agree Agree x 3
    • Like Like x 1
