F1 - 2009
Discussion in 'Motorsports Chat & Race Preparation' started by Steve, Jun 18, 2009.
    Took all of about 14 seconds but I found the email address for Steve Matchette and sent him a note asking why the sidewalls are so large.
  2. ScottinBend
    Article 12.4.2 Of the F1 Technical regulations states that the maximum diameter of a wheel must be less than 660mm with dry tyres and 670mm with wets.
    Article 12.4.4 States that the wheel bead diameter must be between 328mm and 332mm.
    http://jp.f1-live.com/f1/img/regulations/2008tech_en.pdf
    Right, the diameter needs to be 660mm or less for slicks. Why do they use the full 660mm and create a tire with that much sidewall. Thats the question being asked.
    According to the regs it can be smaller.
    The regs are easy enough to find but they don't explain the WHY behind all the specs.
    Yes, the regs only specify the maximum, but the sidewall height can't practically be much, if any, smaller because (as far as I can tell) of the other requirements for dimensions of chassis, suspension, ground clearance below the legality plank, etc. That's why everyone keeps coming back to the max wheel bead diameter as the key. All else equal, the min sidewall height is constrained by the max wheel bead diameter.....I think.
    I think this is why discussions I've seen re the sidewalls have ground down to "Why don't they allow larger diameter wheels?" Either that or we're just very consistently chasing the wrong factor.....and I'll admit that's VERY possible. :crazy:
    Here's hoping Matchette answers Nathan's email, either directly or maybe even on the air.
  5. goaljnky
    3,105
    394
    I've found similar discussions on several other forums. Several ideas are floating around from ride height to tire temperature and longevity. It is even being proposed that the tall sidewall is the byproduct of trying to slow the cars down. Similar to limiting wheel sizes has the consequence of restricting the brake size. So forth and so on.
    Massa had his checkup in Florida yesterday and they decided he'll return to racing in '10.
    He needs some plastic surgery ...
    ... and then some recuperation before he can start training.
  7. goaljnky
    3,105
    394
    Well, he could have used some plastic surgery before the accident.
    //rim shot
    He always reminded me of Eddie Munster a little bit.
    Hmmm, not sure about the Eddie Munster similarity, though he does seem to be about the same size :lol: and he sounds a little like one of those Wizard of Oz Munchkins....with a Brazilian accent.
    Anyway, now that Massa's '09 status is decided, time for the Ferrari gang to pick a replacement. I still say unless they go looking for someone outside the current F1 assemblage it's likely to be Gene. Can't see any real options to pull someone of quality away from another team at this point in the season unless it's a reserve or test driver.
  9. Nathan
    I heard back...
    My email...
    The reply...
    I figured you'd get an answer like "because the rules say so" and I was right! Yet again, no answer as to the motive behind the rules.
    I think I'll send him another question...I assume you found that email address at the Speed site, yes?
  11. ScottinBend
    Yea......didn't really answer our question did it.
    :sad:
    #112 Steve, Sep 3, 2009
    Fisichella is switching to Ferrari as of Monza and for the rest of the '09 season. Liuzzi favored as his replacement in the Force India....hope he does well, I enjoyed watching that car hounding Raikkonen at Spa.
    Strange words from Mallya re Fisi's switch "The agreement will secure Fisichella's long-term future with Ferrari and it would be incorrect to jeopardise this." Given Ferrari's expected wealth of drivers for next year, maybe Fisichella is going to be their test driver next season?
    edit: Ferrari say Fisichella will be their reserve driver for '10.
  13. Nathan
    Supposedly Kimi is done with Ferrari and he's gonna go off and run Rally cars.
    Liuzzi gets the empty seat at Force India. Couldn't be better timing for him since it means he gets to run at Monza; his "home" race. Or I suppose it could be worst possible timing if he screws it up....
    Renault are putting KERS back in their cars. Based on the rhetoric it looks like it's just for Monza though. Interesting to hear descriptions of ways teams are learning to use it. In this case they're saying it's worth it for the race alone but will be even more helpful for qualifying since it not only helps during each flier, but the driver can also to use a full KERS load on the run up to the timing line as a kick start to each timed lap.
    I remember back in the day when there weren't so many standards and regulations....remember way back when the cars didn't all look the same? Any time a team came to a race with some new innovation that made their car more competitive in some way someone else would immediately protest and the rules would usually change within a race or two, outlawing said innovation. Now, in the age of even tighter standards and regulations and a near-spec series F1, we have an innovation only used to advantage by a couple teams and even though it's gradually helping those few teams gain additional advantage over the others, it stays.
    It's interesting that in the same year they changed a mass of rules intending to improve overtaking, one of the innovations intended to help in that effort -- namely KERS -- is (other than at starts) being used primarily in a defensive role to hold off otherwise faster cars attempting to pass. Thinking back, I could definitely see such an innovation being outlawed in the past. The difference here? This innovation was introduced by the rule-makers.....
  15. Nathan
    Ari Vatanen, who will stand against Jean Todt next month in the FIA presidential election, has expressed strong views about the state of Formula One racing. His words will not go over well with Bernie Ecclestone's Formula One group, nor its major shareholder, the CVC Capital Partners private-equity firm.
    "We have races where the [stands] are half-empty, where they are totally subsidized by the government, and now we are struggling to have races in Germany, France and the U.K.," the former World Rally Champion told Europe's Press Association. "If races are so expensive to organize, making the ticket prices so high that a normal middle-class family cannot see them, it means something is wrong. We are in danger of alienating our fan base and undermining our future.”
    CVC's F1 ownership now costs the company about £250 million ($410 million) annually in bank interest, leading in part to the high prices the sport charges fans and race promoters alike
    See there's a huge problem. I knew they'd taken on a lot of debt and that the outlandish ticket prices, etc, were meant in large part to try to pay it down, but I didn't know it was that bad. $410/year in interest alone?!?! Where the hell did all that debt come from in the first place?
    Bernie said ticket prices are going to come down. Of course that's borne of necessity (as ticket sales drop) rather than respect for the fans or interest in the good of F1, and it won't solve the underlying problem. They'll go back to pushing for more revenue generation as soon as they think they can get away with it again.
    As expected, the finger-pointer alleging Renault's conspiracy at the '08 Singapore GP is Piquet. Claims Symonds and Briatore asked him to crash his car deliberately and then told him exactly when and where on the track to do it.
    Here's a majority excerpt from Nelson Piquet's FIA statement revealed (grandprix.com)
  18. ScottinBend
    Wow........and I thought Ferrari was the dominate race outcome designer.
    That is one cool way to win a race, very well thought out........:D!
    IF it's true. That's the question....is it true or is this all contrived, borne of Nelson's desire for revenge. I bet they'll have a tough time finding any tangible evidence.
    Trivia: If they eventually take Alonso's win away Rosberg will finally have one on his record.
  20. goaljnky
    3,105
    394
    I would bet Nelsinho will have a tough time finding another ride.
