1st Gen R53 Cooper S Faulty positive battery cable
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Mini_Chan, Oct 16, 2010.
  1. Mini_Chan
    Mini_Chan New Member
    Oct 11, 2010
    NJ
    Hi everyone, so last week I brought my car to the dealership because my airbag light the one in the center speedo was on. I figure it was a wiring harness and it would be taken care of under the warranty. However, after the diagnostic test, they said I have a faulty positive battery cable. Is this part important? Sometimes when I turn on my car, the light goes off then on. The dealership is asking for $965 to fix it. They said its a bunch of computer work. I don't know is this a common problem with MINI's. My car is an 04 MCS. They also said my wheel bearings needed to be changed because there was a noise coming from the front driver's side wheel, but it turned out to be a loose lug nut. So any idea's on what to do with the airbag light? Is there a way to turn it off because its kind of an eye sore.
  2. beaner
    beaner New Member
    44
    Was the car in an accident that caused the airbag to be deployed? This is really the only reason that the cable could be "bad". There is a device in the cable that blows when the airbag deploys, cutting power to everything but lights and hazard lights. BMW sell a repair kit now. This eliminates replacing the entire cable. MINI doesn't have such a kit, but the BMW one can be made to work correctly.
  3. gbmini
    gbmini New Member
    Surely if the battery cable was damaged, you would not have enough power to turn over the starter motor?
  4. Tron Chief
    Tron Chief "Need More Coffee"
    60
    Maintenance Supervisor Del Monte, retired 30 year
    Lemoore California
    A friend has a 2006 late model and the positive wire was rubbed possibly by a large object (bowling ball) being carried in the boot. The wire shorted to the body below the trim panel about 8 inches to the drivers side of the boot latch causing a small electrical fire until the wires from the airbag sensor to the battery terminal shorted together indicating that the car had been in an accident and exploded the charge that is attached to the positive cable going to the battery. The cable on the 06 and below goes from the battery to the fuse block beside the air box in the bonnet. His was unique in that he had no indication a group of Mini's had gone out for dinner and his car would not start also had that burnt electrical smell. Attempts to jump start did nothing and then we started digging. Eastbay Mini did the repair do to the car being under warrantee but this might be worthy of looking at.
  5. Alan
    Alan Active Member
    98
    New Braunfels, Texas
    I had this same symptom (airbag light) with same remedy (replace positive battery cable from engine bay to battery box). It was done twice before they got it right. Fortunately both times under warranty on my 2003 S.
  6. Motoring Magic
    Motoring Magic New Member
    397
    266
    Thousand Oaks, Vta cty, socal
  7. ZippyNH
    The exact reason why EVERY Mini owner should have a relationship with a Mini Centric shop!!! Big $$ saving for many things, better schedulng Kuching the time, and sometimes good/great advise!!
  8. Mini_Chan
    Oct 11, 2010
    NJ
    could it be possible the light turned on because the tiny plug on the right side of the battery came out? my battery is not fastened into the box like it should be, because the bolt does not tighten. i think its because my battery is moving around that has caused the light to come on
  9. Metalman
    Get that bolt fixed, you don't want the battery bouncing around back there. For one it's defiantly not good for the plates in the battery. After awhile you're going to wear a hole through the case and start leaking acid all over the place.
    So, did the plug come out? If so, plug it back in. Sounds like this bolt is the root of your problems....... maybe.
  10. BThayer23
    I think the tiny plug on the side of the battery is the vent. Not sure if that would cause issues, pretty sure it wouldn't.
  11. beaner
    beaner New Member
    44
    OP: air bag deployed? Other than this, secure the battery and connect the vent, both are unrelated to your issue, however.
