1st Gen R53 Cooper S Finally, Gen1 Power Steering Delete Kit Available Soon!!!!!
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by minsanity, Jun 12, 2014.
  1. Dave.0
    How so you like it in turns at speed? "Thinking Dragon transitions"
    I am not worried about low speed "parking lot" turns.
    How would you rate it on a 1-10 scale?
    1= dead pump
    10 = good working OEM pump.
  2. minsanity
    minsanity Well-Known Member
    Sep 11, 2009
    581
    352
    Good scale, Dave!
  3. minsanity
    Sep 11, 2009
    581
    352
    Must still be out having fun testing. I'd take anything above a dead pump w/ all other PS related issues eliminated.:)
  4. r34king
    r34king Member
    Aug 18, 2011
    71
    34
    Auto Tech NTB Capital BLVD
    I'd say maybe 3-4 Dave. Its very heavy steering under braking because of weight shift. I think after a few days you wouldn't notice it much. But its a lot different than power steering
  5. Dave.0
    Excellent :Thumbsup:
  6. rkw
    rkw Well-Known Member
    443
    Have you owned cars without power steering, and how does it compare?
    My Honda CRX didn't have power steering. It was fine except in tight parallel parking, but you learn to roll just a few inches while turning the wheel. However, the car only weighed 2000 lbs.
    Call me paranoid but this sort of vague instruction always bugs me, and I've seen it a number of times. How much is too much and how can you be sure you've avoided it without leaving it too loose? Do you tighten until you see deflection and back off or have you done permanent damage at that point?
    You need neither warnings nor torque settings for a lot of things but it seems to me a torque setting is in order for anything that requires a precautionary warning about damage potential.
  8. CHKMINI
    With steering and brakes detail is mandatory.
  9. r34king
    r34king Member
    Aug 18, 2011
    71
    34
    I'd say just spin the bolts in with your fingers and the go 1/4 turn further with a wrench or ratchet. The point is to keep water and dirt out, not to let fluid leak science all the fluid is out anyway. I've had cars with no power steering but they had really skinny tires so it wasn't hard at all. I'm talking 155 skinny. Having 205 45 17 on the mini creates more resistance. It's still easier than with a dead pump.
    The directions from condor are spot on for how to do it.
    919-796-2712 if you need help over the phone. I can walk you through it.
    Dan
  10. CHKMINI
    I'm not trying to start a bru-ha-ha, but I work for a front axle manufacturer and if the above listed instruction for tightening any fastener is given instead of a torque spec and an accident would happen, I don't think a jury will be very impressed with "spin the bolts in with your fingers and then go 1/4 turn further....". Just sayin'
  11. r34king
    r34king Member
    Aug 18, 2011
    71
    34
    They are banjo bolts for the steering rack. Not critical to anything structural. If you want to tighten them more then have at it. It is not a metal plate. It is plastic and will deform rather easily
  12. CHKMINI
    Not about to argue with you. I've stated my opinion because I've had the experiences of sitting in that chair next to the judge. Every fastener has a torque spec. for optimum performance. Listing it doesn't transfer liability it simply implies knowledge.
  13. minsanity
    Sep 11, 2009
    581
    352
    I've asked Condor for banjo bolt torque spec. Let's see when he could provide.
    I'd take the 3-4 rating anytime! The good thing is I've got aftearket steering where I could change the wheel diameter. Some can go dorky by adding a steering knob?????:)
  14. Metalman
    Hey now......
    I got one on my riding garden tractor....:blush2:
    Not dorky man.... Not dorky
  15. minsanity
    Sep 11, 2009
    581
    352
    Haha, sorry, man.:D My dad installed 1 on every car he owned. Love the function, just doesn't look right on our gen1s. :)
  16. Metalman
    I'll bet your banjo bolt torque will be around 5-10 foot pounds....
    Just don't want to crush the block and still be tight enough that they don't vibrate loose...
    After all, the block is just serving the purpose of allowing the minimal fluid and air freely move and keep dirt and water from getting into the rack....
    But go with what he recommends... he's making a lot of UHMW PE parts so he'll know...
  17. minsanity
    Sep 11, 2009
    581
    352
    Carlos from Condor is out on vacation for a week. He'll give the torque spec when back. He's asking for 2 feedback ratings. 1 for high speed, another 1 for low. 2 very different conditions which R34king described.
  18. Dave.0
    I can't wait to install mine but unfortunately I have to wait. :mad2:
  19. minsanity
    Sep 11, 2009
    581
    352
    Pump some iron while vacationing, Dave. You might even rate the steering feel an 11 on city traffic & parking.:D
  20. Dave.0
    I never ever go into the city of Filth-a-delphia with my MINI.
    * except to go to Helix which is on the very edge of the city.
