Suspension Brakes Fitment of Strut Brace and Intake Combo Reference 2ND Gen MINI
Discussion in 'Tuning and Performance' started by Way Motor Works, Mar 13, 2012.
  1. minidiver
    minidiver Member
    Jun 24, 2010
    31
    How about a bar to work with the AEM intake?
  2. mattkosem
    mattkosem New Member
    Aug 7, 2012
    9
    #22 mattkosem, Feb 17, 2013
    Same on my '13 R55. Had to file off a bit of plastic above the MAF to keep them apart. NM indicated that this is a common issue with '12+ models because of greater manufacturing tolerances.
    --Matt
  3. oldbrokenwind
    oldbrokenwind Active Member
    Oct 18, 2012
    196
    107
    Northern NV
    '07 MCS with K & N Typhoon air filter. Which strut brace bars should I be considering, that require NO "tweaking" to make it fit?
  4. oldbrokenwind
    Oct 18, 2012
    196
    107
    Northern NV
    Answering my own question --- Tried the BMW strut brace PN 51 71 0 442 352. This could be the one previously mentioned as the "M7" strut brace, but I don't know for sure. Marketed as a "JCW Front Strut Brace", and the box has the BMW info.
    Anyhow, it fits with about half an inch clearance from the air box. Watching engine movement on a dyno, the air box rotates back and down --- away from the brace. Should be good to go --- haven't driven it yet, just finished the install.
  5. Dave.0
    None of them "strut braces" have been proved to anything anyhow in a Mini 1st or 2nd gen. It's all a bling placebo effect.
  6. Jason Montague
    :cornut: Au Contrare! Mine helps a lot but only with BOTH front strut brace and rear frame brace Monseur DaveO. :Thumbsup:
