Fixed camber plates
Discussion in 'Mid-Ohio Motoring Classifieds' started by Crankshaft, Sep 7, 2014.
  1. ScottinBend
    Being low has nothing to do with whether or not added camber is needed. Additional camber aids in getting more contact patch from the tire to the ground during cornering. Being low simply lowers the center of gravity. Two totally different aspects of suspension design.
    MINI's are notorious for having to little front camber. This results in uneven front (and sometimes rear) tire wear when driven hard. Adding camber will reduce this wear considerably.
  2. Crankshaft
    Crankshaft New Member
    Sep 2, 2013
    236
    115
    Sometimes
    Canal Winchster,Ohio
    When you lower a mini you get more camber!
    Not sure what your talking about.
    ^^^ This is absolutely correct.
    Crankshaft maybe you can sell your extra camber on fleaBay. :idea:
  4. Crankshaft
    Sep 2, 2013
    236
    115
    Sometimes
    They are not bothering me to have them sitting around.
    I may take them to the dragon for the swap tent.
    Bet they sell quickly down there. You could use them as paper weights, but too much camber will make the papers slide off your desk. :D
  6. ScottinBend
    You will get some, but no where near what the camber plates will give you AND what would be optimal.
  7. anuppercasej
    anuppercasej New Member
    Jun 11, 2010
    185
    38
    Portland, OR
    The camber plates still for sale?
