Pre Migration ***FIXED*** Problems with Images 11/17/11
Discussion in 'Site Feedback' started by Nathan, Nov 17, 2011.
  1. gds194
    gds194 New Member
    Sep 26, 2011
    281
    None
    Centennial CO
    Good Man!
  2. Jafar
    Jafar New Member
    Sep 1, 2011
    188
    14
    Mfg. Technical Specialist
    Murfreesboro, TN
    What about browsing/searching the badges area? Every time I try with Google Chrome or Safari, no badges show up. When I try with IE it automatically kicks me out and have to log back in then immediately get kicked out (infinite loop).
  3. Justa Jim
    Well, that will do it every time. :)
    Nathan it worked for me just uploaded a new avatar.
    Thanks for all your hard work. :Thumbsup:
  5. MikeMiniJCW
    MikeMiniJCW New Member
    Nov 14, 2011
    32
    Consultant
    Northern Virginia
    All working now!
    Thanks Nathan.
  6. ScottinBend
    #26 ScottinBend, Nov 26, 2011
    test attachment
    it works for me now!
    test
  7. ScottinBend
    OK....that was weird.
    Attached pic was visible in the first post, but when I edited it to say it worked, it was gone.
  8. ScottinBend
    .....and now it is back after refreshing the page.
    :confused:
  9. Nathan
    It has to do with how you edited and the way pages are rendered.
    If you use to back button in the browser to try and edit then you will not see attachments. Being the site uses AJAX to add your post without having to perform a full page call it can cause things to look wonky if you try and go back and edit a post seconds after submitting a post. It can also cause the dreaded double post at times too.
    Suffice to say the image issue is fixed. It was a simple mistake on my end that had massive repercussions.
  10. ScottinBend
    Same thing happened again. Clicked on the edit button on post 26 just now and when I hit the save button the attachment image disappears. It still has the attachment thumbnails "box" but the actual image is not there.
    Attachments are like that. When you go to edit the post with an attachment they look like they have gone away. They are still there.
    Tis better to put the image inline in the post. I'll be adding more Ho Do I's on this very soon.
  12. SNEEEZY - Erika
    1,212
    116
    Female
    A double-posting gremlin is lurking...
