Flat top jack stand
Discussion in 'MINI' started by ScottinBend, Jan 5, 2010.
  1. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    Hey that sounds like an idea, I have about 100 pucks at home :Thumbsup:
  2. PGT
    PGT Wheel Whore
    Federal Gov Contracting
    Leesburg VA
    I got mine with the jack from Costco. Returned them when the jack turned out to be a worthless POS that locked with a load on it (lifting one end of a car and it seized....so much for 1.5T capacity...the rear of a Subaru weighs half of that at most).
  3. ScottinBend
    Great suggestions, thanks. Was hoping to find something a bit less pricey, but maybe not.
    Anyone have any issues with the base sizes on the flat top stands? 7" seems a bit on the small size.
  4. ScottinBend
    :Thumbsup:
    And the fact that they are designed to be used under an axle or other round support.
  5. moreorless
    moreorless New Member
    Aug 17, 2009
    343
    14
    In a pile of sawdust.
    Here's my solution......
    I made my own....sort of.....these fit into the molded jack points on the MINI.....
    Take a 2x4 and cut off a chunk 6" long. Cut a piece of hardwood a wee bit shorter and narrower but a wee bit TALLER than the jack point on the MINI. Pre-drill hardwood and glue and screw onto center of 2x4.
    Next mark on reverse side of 2x4 where your curved jack stands touch and carve that are out to fit. Center as best as you can and test fit often.
    When done, your curved jack stands are now flat jack stands with maybe 50 cents and a half hour spent.
    Repeat 3 x's. Now your MINI is up off the ground and rock steady. I jack up a side at a time.
    ...Les
  6. ScottinBend
    Hmmmmm.....I like that mod !
  7. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    You don't need all that. I use hockey pucks, they are 1$ each at my local Play it Again sporting goods store.
    I have some that are modified to fit into the OEM plastic lift blocks.
    They are just pliable enough to conform to the jack stand contact point.
    I'll post a picture if you like.
  8. moreorless
    Aug 17, 2009
    343
    14
    Please do!
  9. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Norm, please do post a photo if you get a chance
  10. Norm03s
    Norm03s New Member
    534
    When I get home tonight or Saturday morning I'll put some pictures up.
    Nice idea Less. I may have to do something like that, but of course will use some of the handy man's secret weapon on them.
  12. mini_man
    mini_man New Member
    Jul 27, 2009
    OutMotoring sells them: GP spacers
  13. Norm03s
    Norm03s New Member
    534
    My Hockey puck jack stand pads
    The strip of rubber on top is secured with a cut down lag bolt and rubber cement. I counter sunk the washer and nut in the
    bottom. They fit so well that I have gone off for a test drive, forgot to remove them and they were still in the plastic blocks two days later.
    I found the rubber used for the strip along the railroad tracks, they use it under track bedding plates on concrete at crossings.
      File size:
      62.5 KB
      270
      File size:
      40.7 KB
      119
      File size:
      55.9 KB
      134
      File size:
      49.8 KB
      122
  14. RonsMinnie
    RonsMinnie New Member
    449
    Sugar Land, TX
    Nice idea -- Good work!
  15. agranger
  16. Rally
    Rally New Member
    50
    Ohio
  17. Norm03s
    Norm03s New Member
    534
    #37 Norm03s, Jan 10, 2010
    Humm, look's like mine except X25 more expensive. Oh yeah they are so cheap to make I have 4 so I can get the MINI way up in the air!
    Do I need to post a picture of a doubled up 12" lenght of 2"x8" lumber to use as a mini ramp, raises the lowered car 3" so you can get your jack under it?
  18. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Norm, if one doesnt have a strip of rubber from a railroad, what else would you suggest for the top piece? Would a cut hockey puck work or too brittle? A strip of plywood?
    These commercial adapters are round and have metal contact areas. The size and shape seems based on using them to mate up a typical floor jack (with a round lifting point/cup) to the stock jack point (check the Moss link ^ ^ for example). That's great if that's what you want them for, but there are places other than the jack points where you can lift with a floor jack, and I'm usually trying to lift elsewhere so I can set the car down on jack stands at the jack points. I'd rather have stands with round tops with rubber surfaces or something like the hockey puck solution since at least that way it's not smooth metal on metal so there should be some friction plus the rubber should conform to an extent to whatever shape of the top of the jack stand.
  20. Norm03s
    Norm03s New Member
    534
    #40 Norm03s, Jan 10, 2010
    Cut up a semitrailer mud flap. If bias ply tires without the steel cords were still around I'd suggest a piece of that.
    A strip of good plywood would work, you could glue a piece of red rubber to the top for an interference fit so they would stay in place while you adjusted your jack stand.
    But really, the strip just locates and keeps it in place until the puck becomes the load bearing point.
    Hockey pucks have a very high durometer hardness but are still complaint, they grip and conform very well on both types of my jack stands.
