Engine Drivetrain 1st Gen Cooper S Fluiddamper crank pulley anyone try one?
Discussion in 'Tuning and Performance' started by 00zero, Oct 21, 2011.
  1. 00zero
    00zero New Member
    Oct 2, 2009
    92
    Pittsburgh. Pa
    Ok, i know the ATI is the general recommend crank damper for the mini.
    I know ATI is used in NASCAR and race cars all over the place.
    I did a bit of internet research and found that in a race situation it seems like ATI is the way to go. It also seems that the difference is...
    The ATI is tuned for a specific resonance / dampening and that tuning can be different for different power output.
    The fluid damper is not tuned to a specific resonance / dampening it dampens more throughout the frequency range.
    In my mind i see ATI race car and Fluid daily driver.
    Most of the information is for high powered V8 and they all seem to go ATI while the high revving honda guys go Fluid, endyn swears by them.
    Has anyone used the fluid? What are everyone though?
    -Jonathan
    PS
    i also know the whole fluids are not allowed in NASCAR but we aren't driving at 10,000rpm for hours are we ;)
  2. Jan
    Jan Well-Known Member
    377
    382
    I have used the fluid damper on our 400hp car..........works like a champ
    I think minimarks and others on this site have it too.........
  3. minimark
    #3 minimark, Oct 21, 2011
    There is a fluid dampener on mine, works great, much smoother!! Got it from RMW!
    .....just my 2 cents.
  4. AliceCooper
    AliceCooper Club Coordinator
    Mar 13, 2010
    643
    123
    CT Technologist
    South Florida
    ATI like you read is the best and I know lots of folks who run them on thier daily drivers. Summit racing as well as Jeggs performance seem to have the best price on them for the Mini.
  5. BThayer23
    I run the ATI pulley. OEM failed on track around 90,000 miles. 8 track days on the ATI and no issues. It has some bolts that stick out farther than oem, and those shredded my brake ducts, but that's not the pulley's fault. Keith at Werkin Mini knows a lot about the ATI pulley.
  6. Nathan
    Went with the ATI too when my OEM gave up at like 60K miles. Obtained with the help of Way Motor Works and OutMotoring.
  7. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    -Jonathan,
    You sorta answered your own question about the two in your opening thread.
    And a very good point about most 99.9% of us MINI drivers...
    And this is a very good point as well.
    Your quote:
    "i also know the whole fluids are not allowed in NASCAR but we aren't driving at 10,000rpm for hours are we"
    I have used and owned both ATI and Fluidampr for years on various engines. Testing the relative performance is a bit difficult but I have personally tested on a controlled engine connected to a Engine Dyno doing a back to back comparison run of different bolt on parts found NO difference in the output of the engine worth mentioning. I would say flip a coin find a registered dealer of either and call it a day. You can't go wrong with either one of these units.
    Currently one of my MINIs engines I use an ATI
  8. minimark
    ^ This.
    Nothing wrong with either one. The fluid is cheaper and Ian Stewart was running one on his National Championship Mini, so that was good enough for me.
    Conversely the ATI is a tick lighter, so you really can't go wrong either way.
  9. yellowbritishrocket
    May 16, 2009
    618
    277
    i have the fluid dampened one on mine....i love it...ive had it on the car for well over a year now and not one issue at all...plus its cheaper than the ATI
  10. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    I'll sell you either one you end up wanting but I recommend the ATI over the fluid damper.
  11. jiminni
    jiminni Well-Known Member
    262
    Ca.
    Smoother compared to what?
  12. minimark
  13. jiminni
    262
    Ca.
    So how would someone actually measure something like that? Do you have the equipment for measuring them scientifically? Like these guys:
    Noise and Vibration Analysis and Measurement
    I would have thought that BMW would have really thought this one out, as smoothness was one of their number one goals in these cars. Hence all the soft rubber bushings they used in the suspension, ultimate performance was sacrificed for smoothness? No?
  14. minimark
    Purely my opinion and one gleaned from my own Butt Dyno Jim, so tell Lynn for me please.
    Thanks
  15. minimark
    PS: Feels much smoother on an actual road race track too!! 2 cents
  16. jiminni
    262
    Ca.
    So then you really don't know do you. I personally use a solid pulley design used by hundreds of million miles of other MINI owners. BTW, I think Lynn already mentioned he uses a ATI. So go tell Jan for me please.
    Thanks
  17. jiminni
    262
    Ca.
    So since 99% percent of us MINI owners don't track their cars this makes sense how? 2 cents
  18. minimark
    :cornut:
  19. Jan
    377
    382
    not quite sure what the bickering is about, we have run both type pulleys and the fluid damper WILL cover a wider band of dampening. It is ALSO HEAVIER...... we worked with PRW to make this damper. It will definitely smooth out the engine. We also ATI, it's whatever floats your boat and your pocket book
  20. Metalman
    I like purple.... Sometimes I like green.... Don't ask me to measure it...
    Oh, and I also like ham.....:D
