Hey Guys, When I had my new tires installed a couple months back the installer completely redid the weights when they aligned the car. Any tips to remove the remaining backing? Check out the bottom of the wheel for a example
Yeah - I've used by googone and WD40 on those - saturate it well, and let it sit a while. Use a plastic tool to scrape as needed. Multiple applications may be needed to get it all off.
Used the WD40 cause I thought multiple spray applications would soak the backing a little better That and a former plastic cheesecake slicer and it all came off pretty easily (Wheels were also pretty warm from the commute from the office) WD40 also pretty good at removing road tar Washed and re-waxed and all is happy in Augie's wheel world. Lookin' good! Thanks guys!
