Suspension Brakes 1st Gen Front Control Arm Bushing, what brand do you use?
Discussion in 'Tuning and Performance' started by M^Cubed, Aug 19, 2009.
  1. ScottinBend
    What turned you away from the PSRS?
  2. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #42 Nitrominis, Aug 20, 2009
  3. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    That is a no-go then! Wow, we are really working what is available out there
  4. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
  5. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    and found this one elsewhere [​IMG]
  6. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #46 Nitrominis, Aug 20, 2009
  7. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    You know you wouldn't have to worry about any of this grease issue if you got the PF. They come with a tube of grease.
  8. ScottinBend
    Nothing wrong with modding a part to make it better.
  9. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #49 Nitrominis, Aug 20, 2009
  10. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    I was defiantly looking for the right stuff from the get go. I read stories about "bind" or as Lynn has said 'Sticktion'. I want to prevent that from happening for as long as possible.
    Since we seem to somehow hit upon a difference of terms vis-à-vie grease and lubricant and I'm a fan of etymology:
    Lubricant - A substance used to reduce friction between objects or surfaces. Lubricants include grease, powders (dry graphite, PTFE, Molybdenum disulfide, tungsten disulfide, etc.), teflon tape used in plumbing, air cushion and others.
    Grease - A lubricant composed of an oil or oils thickened with a soap, soaps or other thickener to a semisolid or solid consistency.
  12. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    Thanks for the definitions Nathan.
    When you say grease, I automatically think of a petroleum type of substance and lubricants make me think of water/glycerin based type stuff HA HA HA - KY Anyone
  13. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #53 Nitrominis, Aug 21, 2009
  14. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Some thoughts on sticktion and the like...
    Solid race bushings have huge stiction issues (ever been in a race car driven in anger with the sound deadening removed? They groan and creak like crazy!), but really it doesn't matter at all. The lever arm on your typical suspenion component is on the order of feet, and the moment for the bushing surface is on the order of centimeters. To to some extent the stiction does result in a non-linear force, it's so small compared to the rest of the forces at play that you can ignore it in any consideration of driving dynamics. It makes noise that's a pain, but it doesn't effect handling. It can be a sign or indicator of faster wear (Depending on materials), and for a car that doesn't get torn into often, that can be the bigger concern.
    One of the dangers of wet lubricants though is that dirt and other crap tend to get burried in them, and this can make a kind of liquid sandpaper that leads to faster wear.
    Now Greg did some measurements of the required force to deflect the BavarianAuto units, and found it took about 125 lbs to deflect them to the fullest extent of suspension motion. At first, this seems like a lot, but then, the spring is going to take many times that amount to deflect as far, so it's less than a 10% change in spring rate (even with stock springs). the percentage change is much less when you get stiffer aftermarket springs on them.
    Seems to me:
    Stock is forgiving and quite, but is prone to failure and alows a lot of motion.
    Poly inserts stiffen up the stocker.
    Powerflex and the like are stiffer, and need some periodic maintenance.
    Alta unit needs welding.
    BavAuto units are really stiff (because of the single piece design) and still need some periodic maintenance, but maybe not as often as the Polyflex/MiniMadness style.
    None are perfect, and they all have thier issues. No matter what, you'll be under the car taking care of any of the aftermarket (though the Altas seem to do well after welding). Or you'll be under the car changing out the stockers!
    Matt
  15. goaljnky
    3,105
    394
    Hey Matt,
    Instead of the long explanations, how about the auto up/down for the verts? I am just sayn'.
    Hey, I like the long explanation. :prrr: Of course I don't have a vert.....
    Wondering why this is the first time I've heard of poly inserts for the stock bushings. Time to do some searching.
  17. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    Trying to decide which to go with, I know now that I need to replace mine.
    Alta PSRS, need to be welded, anyone have pics of where and how much. I have a wire feed MIG, is it just a tack job?
    Whats the life expectancy of these various bushing offerings from your experiences.
    Guess to I'm looking for the longest lasting, best working, fiddlefree part to install, then again aren't we all... well most of us anyway.
  18. Nathan
    Tack the arm to the sleeve
  19. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #59 Nitrominis, Aug 23, 2009
  20. not-so-rednwhitecooper
    Aug 5, 2009
    40
    mechanic
    Chardon, Ohio
    How deep is the hole in the end of the control arm? Why not drill that out a bit larger, tap it, and use a bolt and washer instead of welding? Seems to me that would be a better way to go.
