Suspension Brakes 1st Gen Front Control Arm Bushing, what brand do you use?
Discussion in 'Tuning and Performance' started by M^Cubed, Aug 19, 2009.
  1. ScottinBend
    #141 ScottinBend, Sep 15, 2009
    Pretty much already hashed out,
    :lol:
    Last words........loving mine!
  2. phydeaux
    phydeaux New Member
    Maple Valley, WA
    Heh. I suspected that might be the case.
    Still keeping an eye on the thread, of course, since I'm always open to new info and ideas.
  3. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    My Alta bushings are being pressed into brackets for me by Way motor works this week at a 50/50 attitude so to speak. Ryephile mentioned doing them that way and I like the idea so I'll see how it work's out. ScottinBend love's his and his club has had good stuff to say about them. I had started out thinking Poweflex but after seeing the video, that and input from Alta PSRS users changed my mind.
    I need to fix my MINI now, can't wait on something else in development.
  4. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    Just FYI... the video is for a completely different design than the Powerflex. You can't say you can't say "I don't like the milk from the bull, so I went with the dairy cow"
  5. Norm03s
    Norm03s New Member
    534
    what?:confused5:
  6. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    You stated "I had started out thinking Poweflex but after seeing the video"...
    The video was the bavauto bushing witch is 100% solid. The powerflex and mini-madness bushing are multiple pieces.
    That would be like comparing the alta vs. a solid piece of aluminum.
    Make sense now? You can't compare something if they are not the same design/function.
  7. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    But the video overstates the problem
    So what it takes 125 lbs or whatever to go to full deflection. That's what, 5%-10% of the weight that it takes to go to full deflection with stock springs? Even less with stiffer aftermarket ones....
    It's much less of a deal than the video makes it out to be.
    Matt
  8. jhiggs26
    jhiggs26 New Member
    May 24, 2009
    159
    10
    5000+ Miles on my LCA Powerflex bushings and I'm still loving them. I did the Powerflex stock sway bar and steering rack bushings at the same time too. :aureola:
    Jeremy
  9. Norm03s
    Norm03s New Member
    534
    That's oK , Alta PSRS, this time Poweflex or some yet to be released bushing next time. Ah wait.. no.. uM,, never mind thats:cool:
  10. andyroo
    andyroo New Member
    227
    6
    Columbia, MD
    Norm, i'll probably get the powerflex bushings eventually. i've only got about 30k on my car, so the stockers should be fine for now. theoretically.
  11. UKCoopeR
    UKCoopeR Active Member
    May 21, 2009
    293
    109
    VA,USA and UK
    mine were shot at about that mileage...
    changed them at 32k and was blown away by the handling all over again
    new bushings even oem (what i got) make a huge difference from worn ones
    ^some track / autoX use tho
  12. ScottinBend
    Same here......30K and the passenger side came off in pieces.
  13. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    I have 17K on my car and they are already cracking.
  14. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    If they're craking...
    they are more shot than you think. This really is one of the worst parts of the Mini suspension.
    Matt
  15. andyroo
    andyroo New Member
    227
    6
    Columbia, MD
    Crap.
    - Andrew
  16. phydeaux
    phydeaux New Member
    Maple Valley, WA
    I imagine that at 79K miles, I've got nearly nothing left, then.
  17. paulsminis
    paulsminis New Member
    Contractor to the Government
    Dayton, Ohio area
    #157 paulsminis, Sep 24, 2009
    I can add another $.02 to the discussion. I am not a frequent poster, but I read most everything. The how-to-do-it for installing the PSRS on the R56 that Chad wrote up, is illustrated on my car. We did the install ("we" as in, Chad did the install, I turned wrenches and assisted where I could, staying out of the way when I needed to). That was done in the middle of winter in Detroit in early 2008. This was before anyone knew about welding the sleeves on (heck, it was Chad's first R56 install). 20K miles later, several track days, lots of daily driving including some long trips, they are still doing fine. The sleeves have stayed put, and I really enjoy the benefits of a much more fun to drive car. Hard braking at the end of long straights no longer brings the side-to-side dance that even brand new OEM bushings demonstrate. I periodically crawl under the car when I am changing brake pads, changing wheels, whatever, and check the set screws -- I have only once found one even slightly loose -- blue loctite continues to do its job. All this is on a car that lives outside 100% of the time, through Ohio winters, with the demon salt. In fact, the day I drove up to Detroit, they were enjoying a nasty winter storm and it continued most of my 5 hour trip back home. Nothing like a baptism under fire -- er... cold and salt.
    Sure there are some noises in the suspension on my car, but I can attribute none of them to the PSRS. I will replace them if they ever show the wear Dr Mike has seen.
    Oh, and one more thing --- another local R56 MCS owner wants to install the PSRS in his car. He checked around for someone to install them -- I absolutely did not volunteer (remember, I've seen this job as well as assisted my neighbor when he installed
    BAV Auto ones in his R53) -- I don't have the garage space to let a car sit for a day while we find someone to press them in. He finally checked with our dealer. He (and I) was astonished when they said they would install the PSRS for free, as his car had sufficient miles to mean the stock ones needed replacing. Let me clarify that the customer will supply the PSRS, but the dealer will install them for no labor charge -- charging it to warranty work!!!! It might be worthwhile to check with your dealer if your car is in the 35K mile or higher and still under warranty!
    Paul
  18. Norm03s
    Norm03s New Member
    534
    Thanks Paul, no concerns going forward.
  19. Doggybags
    Doggybags New Member
    Just as an FYI, the Alta PSRS's are currently 50% off on their website. Just ordered a set.
  20. Norm03s
    Norm03s New Member
    534
    That's a good deal!
