Front right wheel "creaking" noise. Ideas?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by minyme, Jul 27, 2019.
  1. minyme
    minyme New Member
    May 24, 2015
    23
    15
    2008 Mini Cooper R52. Adding a link to a video. Alot easier to hear it than me to explain it. Does not make the noise with the tire off the the ground, no weight on it.
    Sent from my SM-N960U using Tapatalk
  2. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,703
    924
    physician
    York, Pa
    Sounds like an upper strut mount to me.
    You should be able to confirm or dismiss
    this by listening there with the hood up
    while someone thorns the wheel for you.
    If so, replace with a good brand (Lemforder).
    If it looks good but just creaks, it isn’t an
    urgent issue, just annoying. If the rubber is
    cracking and starting to deteriorate, then
    fix it sooner than later.
    • Agree Agree x 3
    • Like Like x 2
  3. minyme
    minyme New Member
    May 24, 2015
    23
    15
    Just confirmed, that's exactly what it is. Thank you.
