For Sale: A used Alta Rear Swaybar for R53 MINI (it may fit others; check with Alta). 3-way adjustable; 22mm in diameter. Includes bushings and brackets. Claimed rate increase over stock bar: Bar Setting #1 213% Higher Rate / Effective Rate =250 LBS/IN Bar Setting #2 260% Higher Rate / Effective Rate =305 LBS/IN Bar Setting #3 329% Higher Rate / Effective Rate =386 LBS/IN Used, but great shape. Usual scrapes and scratches you would expect after being on the car for about 18 months. This is a great bar for autocross or track. Can also be used on the street, but expect a harsher ride. You can install it yourself, but expect to have to drop the rear sub-frame enough to clear the thickness of the bar end to wiggle it in. Price: $100. Shipping to lower 48: $25. PM if interested. Paypal preferred.
