Sold: A set of used fixed camber plates from Ireland Engineering for the R50, R52, and R53. These add approximately 1.25 degrees of negative camber to the stock front suspension and up to 2.1 degrees of negative camber when used with lowering springs like H&R Sport Springs. The stock Mini has very little front camber. This additional camber really improves handling without significantly affecting tire wear. They do not require drilling any holes and your strut brace will still fit. May cause spring binding if your springs are wider than stock. The bearings have been cleaned and repacked and move freely. (Recommend you clean and repack them annually if you live someplace that salts/sands the roads.) Includes new nuts/washers not shown. Recently repainted. PM if interested or have any questions. Price: $95 shipped to lower 48. Paypal preferred.
