Fuel cleaner, Fuel Additive, Bad Gas?
Discussion in 'MINI' started by 05r50, Nov 21, 2012.
  1. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
    So for the second time this year I have experienced a CC-ID 029 code right after a fill up. The last time it happened I determined it was the grocery gas that I had used since it cleared up on my next tank once I switched to Shell 93.
    I have been using it ever since, but the symptom returned today. I guess it is possible that the Shell 93 I bought yesterday has some crud in it, so if that is the case, what additive can I add to my full tank of fuel to help clean out this problem?
  2. minsanity
    minsanity Well-Known Member
    Sep 11, 2009
    581
    352
    That seems to point to insufficient in-tank fuel pressure. Check gas cap, maybe?
  3. CHKMINI
    Jeff, is this the same issue that you had at the Dragon?
    Jeff you need to flog that MINI harder. Pouring a bottle of Chevron Techron in the tank will do no harm & could help. That's all I've got???
  5. 05r50
    Dec 4, 2010
    1,269
    696
    That is correct. It is the same issue.
