Fuel mixture Code
Discussion in 'Starting Line - New Member Introductions' started by carlos, Jan 29, 2015.
  1. Dave.0
    Have you ever had the car walnut blasted to clean the back of the valves since it’s a direct injection motor.
    Carbon build up cause all kinds of issues that have lead many on wild goose chases looking for other issues.
    I have the same code reader it works well. If you have an exhaust leak that is where your problem probably is. Dave is right carbon is a problem on the N14 engine. Its more of a problem on the S, but you may want to check the intake to make sure its clean.
  3. DneprDave
    The non-turbo N12 motor doesn't have direct injection, it has port injection so, the intake valves are continuously washed by the injectors. No carbon build up problems on the N12 engine.
    • Like Like x 1
    • Winner Winner x 1
  4. 2tallcurtis
    2tallcurtis New Member
    May 16, 2018
    Oh my bad, n12 then? All I know is it don't have a turbo/supercharger, it was late too.
    Thanks for the tip!
  5. MCS02
    Oops your right!!! sorry
  6. Dave.0
    Ooops, my fault. I guess I will crawl back under my R53 / W11.
