Garmin Mount
Discussion in 'MINI' started by Boxcars, May 20, 2010.
  1. Kellen@Craven
    Kellen@Craven New Member
    36
    Talking about Minis and stuff
    Portland, OR
    Looks solid Minidave. You made quick work of that, you have a nice eye and some handy skills. There is always a tough balance between form and function and it looks like you made that mount sturdy without making it an eyesore.:Thumbsup:
  2. Minidave
    #42 Minidave, Aug 24, 2010
    Thanks for the kind words, it definitely works better having it a little higher and further out, and it doesn't bounce a bit. I could use an extra long screw and spacer for the third leg if you have any lying about tho! :D
    All I had was some 2" X 1/4" flat aluminum bar stock to cut it out of, if I would have had something wider I could have cut it all in one piece instead of having to weld the leg on. I diidn't try to do the fancy expanded parts around the screw holes like Craven does tho....:cool:
    And I agree, aesthetics are important too; something can be robustly made and still look good, that's part of why I liked the original part I bought from CravenSpeed, which I pretty much blatantly copied, BTW.:devil:
