Gas additives
Discussion in 'MINI' started by pre shrunk, Mar 3, 2011.
  1. pre shrunk
    pre shrunk New Member
    Dec 12, 2010
    17
    N/A
    E. Tn., very near "the snake".
  2. Jason Montague
    :cornut: Some other people will come up with suggestions but, most people around here use Seafome or plain water with the engine running and through the air intake hose at the port for the PCV hose. Thick clouds of white to black smoke exit the exhaust a viola, carbon build up gone. Check our Library for instructions.:Thumbsup:
  3. Mr. Jim
    Seafoam +1 :Thumbsup:
  4. ronnie948
    ronnie948 New Member
    Sep 9, 2009
    210
    36
    Daytona Beach, Florida
    Techron used here.
    I just put in some "TECHRON" about every 5,000 miles. I have 19,000 trouble free miles right now.
  5. DneprDave
    It sound like snake oil to me, I wouldn't wast my money on it.
    The reason you had carbon build up is that your MINI has a direct injection engine, carbon build up is a problem on all direct injection, spark ignition, engines. Because the gasoline is injected directly into the cylinder, there isn't any fuel mist to wash the oil from the Positive Crankcase Ventilation system off of the backs of the intake valves. This oil gets cooked onto the intake valves and slowly builds up until it causes run-ability problems and must be mechanically removed.
    Seafoam treatment, sprayed directly into the intake manifold, will help, if you start with clean valves, and treat it regularly. It'll remove small amounts of cooked on carbon, but if you already have a large build up, it isn't effective.
    The one preventative measure that will work, is the installation of an Oil Catch Can. An OCC will collect the oil and water vapor drawn out of the crank case by the PCV system and prevent the oil from getting to your intake valves.
    You must remember to empty your Oil Catch Can periodically, or it will over flow and slug the engine with an emulsified mix of oil and water, this can do significant damage. So check it weekly, especially when the weather is cold.
    Dave
  6. Person Moved On
    Person Moved On New Member
    110
    So this brings up two questions
    1) Is it a given then that you'll have carbon build up?
    2) how hard is installing the catch can and why didn't MINI install one?
    (I know that was 3)
  7. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    1) yes
    2) don't have one installed, keep up with the seafoam
    3) for all the reasons MINI avoids doing the right thing, $
    At the same time I gotta say that if they put in a component that actually needs pretty close management you know someone is not gonna check the OCC and try to have MINI pay for the repairs
  8. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    MINI would rather charge $700 every few years to clean your valves. I think Tim's completely right though, if OCCs came standard and the typical driver had to check it every couple of weeks, the majority never would. Most people have enough trouble remembering when to change their oil. In addition having a component that needs bi-weekly attention would A) scare off some potential owners and B) be a source of ridicule in the automotive industry, that in this day an age a new vehicle would need so much attention
  9. CheckersSD
    CheckersSD New Member
    Mar 3, 2011
    129
    6
    Full time student @ UCSD majoring in PoliSci, and
    San Diego, CA
    Jason,
    where is the instruction located in the library. I looked and was unable to find it.
  10. Metalman
    Try here....
    [ame="http://www.motoringalliance.com/forums/showthread.php?p=15224"]How-To Seafoam Treatment R55/R56 - Motoring Alliance :: MINI Cooper Forums[/ame]
  11. jcauseyfd
    jcauseyfd New Member
    May 25, 2009
    201
    31
    Graham, NC
    Because the effectiveness of an OCC is not as clear cut as the posters here indicate.
  12. Minidave
    4,592
    Zactly....
    Nor is it a given that every car will have carbon buildup on their valves....
    It's possible, but not conclusive. My '09 Clubman S has 30K on it, no evidence of carbon fouling in my engine yet....
    Those who are championing Seafoam treatments are doing that company a wonderful service in promoting their product, and if they believe it works for them, well more power to 'em.
    I remain unconvinced....
    However, I do know that there are cars who have and are suffering from carbon buildup, I would like to know the real reason - whether it is truly from oil vapor, or driving habits, poor tolerances in the engine, lousy gasoline, ethanol, infrequent or too frequent oil changes or just what the heck is going on here....
  13. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Virtually every MINI has some form of carbon on there valves,piston domes and combustion chambers. The only exception may be those running water injection post IC or alternative clean burning fuels.
    A simple and inexpensive tool to confirm any carbon question.
    Search results for: 'borescope'
  14. LASRGUY
    LASRGUY New Member
    Nov 16, 2010
    10
    Laser Scientist
    Newbury Park, CA
    Finding a location to mount the OCC is not always easy. I had to get a bit creative to find a solution to work with my intake. I posted details on my install here:
    MINI COOPER :: North American Motoring - BSH OCC install with DDMworks Race Intake
    Installation of a water/methanol injection system is also cited as a great way to keep the intake valves clean. Methanol is a pretty decent solvent. This would require some extra effort maintaining a methanol supply for filling the WMI tank. At least one WMI system supplier advocates simply using -20F windshield washer fluid which is 35% methanol but I'm no expert on this. The cost for these systems isn't any more than the $700 someone mentioned for a carbon deposit cleaning at the dealer.
  15. Rae
    Rae Club Coordinator
    Oct 14, 2010
    907
    Oregon
    My mechanic swears by 44 K at every oil change, and it doesn't make scary smoke come boiling out of you car. Just my .02
  16. countryboyshane
    countryboyshane New Member
    Jul 23, 2009
    202
    Diesel Engineering
    Bloomfield Hills, MI
    The real trick with BG 44K is trying to find it anywhere near me.
    I've also stuck with Seafoamin' the R56 S at every oil change.
  17. CheckersSD
    Mar 3, 2011
    129
    6
    San Diego, CA
    #17 CheckersSD, Mar 6, 2011
  18. Rae
    Oct 14, 2010
    907
    Oregon
    Nope, do it before! You want as much performance as you can get.
  19. CheckersSD
    Mar 3, 2011
    129
    6
    San Diego, CA
  20. Firebro17
    I agree with the suggestion to add a bottle of Techron to your fuel every couple of tanks, or use Chevron gasoline with the additive already in their mixture (my personal choice for years). Having owned a BMW of some sorts for over 30 years my good buddy, a 30+ year veteran mechanic at the local BMW dealership, dropped the Techron idea to me years ago. Also, the suggestion of the OCC is valid as well... Checking it may not need to occur every two weeks as was suggested earlier. Every car will be different... Once you get a feel for your car's internal performance habits, checking the can will become only as frequent as need be. I check mine once a month or greater and find very little residue in the can and even less reason to fret over the routine inspection.
    Here's a couple pics of my install on my R53. :beer
