Gas cap problem
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Goldsmithy, May 8, 2018.
  1. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    I have a really weird problem dealing with my gas cap coming off when driving. Happened twice on my way home from the dragon. I would find the cap outside the closed gas cap door...as if I just closed the door w/o putting the cap on. I know I put the cap on tight when gassing up. I'm at a loss and no amount of searching turns up anything like this problem. Anyone have any ideas at all?
    They say the Mind is the first to go:D
  3. DneprDave
    It's gremlins!
  4. MCS02
    Have you looked ar the cap good? maybe one of the tabs ore bad letting it come loose
  5. wmwny
    4,048
    2,246
    It's nothing a strip of Gorilla tape won't fix!
  6. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Once after having my emissions checked the guy that checked the cap broke it, or so I thought. Those little metal tabs are stationary but the plastic part around them can move. Try to twist it left, I believe, and make sure it's seated all the way to that side then screw it back on and go on a test run.
    Gremlin's it is..... :D
    • Like Like x 3
    • Funny Funny x 1
  8. BavarianTom
    BavarianTom New Member
    May 5, 2018
    Repair shop
    Woodstock GA
    I have seen this a few times with the MINIs and BMW's. We just replace the cap and have no issues after that.
  9. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Welcome to MA Tom!
  10. BavarianTom
    May 5, 2018
    Repair shop
    Woodstock GA
    Thanks Qik! here to help with what I can:D
  11. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Thank you, thank you, thank you. I was beginning to think I was nuts. Welcome to the best MINI site out there. Your participation is greatly appreciated.
  12. wmwny
    4,048
    2,246
    You're not nuts, Teddy. Gas caps wear out, but we never seem to think about that when we have other mods to fry first..
  13. Dave.0
    I think you had too much crack at the Dragon. Hahahahaha
  14. agranger
    1,486
    A few too many beers there as well...
