I need the sway bar mount and the metal bit that goes between knuckle clamp. basically all the brackets below the spring seat, or just the strut less the springs etc.
Thanks Steve, do you have enough brackets for 2 struts? can you grind the welds off? or are you going to send the complete body?
I think I have both. Should have everything left over from replacing with coilovers. MINI made changes to the suspension early during Gen1 production. I don't remember the details so let's compare production timing and I'll check to see if the part #s match. Switching this conversation to pm.
