I actually ended up changing out the plugs and coils. Fixed it right up. I had a misfire along with the code.
Oops my bad. 2008 S hardtop. And yes I checked it and it says fuel level sensor but as I stated I've seen where some have changed it and that didn't fix the code. Haven't seen any evidence to support that it will clear the code even though that's what it says it is.
it may be the hpfp, high pressure fuel pump. I found this in another forum. The guy had the same code as you,: turns out the high pressure fuel pump was starting to fail. Apparently issues with it have been sufficient that MINI has raised the warranty period on the fuel pump to 100k miles.
I've still got 12k miles before it runs out if that is the case. Only problem is if its not that I have to pay the service fee for testing it.
In the library there is a ECU chart. It lists P2065 as "P2065 - Fuel Level Sensor 'B' Circuit". Not sure what it means. The ECU chart is here for 2nd Gens. http://www.motoringalliance.com/library/all-about-mini-coopers-17/ecu-codes-chart---2nd-generation-mini-102/
