Feedback GMAP Codes
Discussion in 'Site Feedback' started by Gil-galad, May 29, 2018.
  1. Gil-galad
    Gil-galad Club Coordinator
    May 19, 2009
    1,178
    431
    Decorah, IA
    Is it just me, or does it appear that the site isn't recognizing Google Maps HTML code inserted using [GMAP][/GMAP]? Looking at all of the existing state-specific entries I see lots of preexisting code but no maps.
    I was going to upload some route recommendations but figured I'd wait until I was sure about this.
    @Gil-galad I just passed this to Sully to make sure he would see this.
  3. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Interesting - I have the google API installed. Let me look into this and see if there is something else I need to add/change. Thanks for bringing this up.. I’ll get back with you.
  4. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    So did some quick research.. appears this isn’t native for XF. So I will need to do as an add-on or do some development. Still researching though... as am researching while sitting at boys swim meet.. :)
  5. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Can you send me an example link you are trying to use? Appears there are a number of different ways to do google maps file integration.
  6. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Scratch that - I see the links in that section.. looking into this. Appears there was a plugin on vb to allow for this. Trying to find one for XF. Also, I need to "learn" how to use this feature of google.. so I better understand the options. From what I understand you can actually export the map as a GXF file.
  7. Gil-galad
    May 19, 2009
    1,178
    431
    Decorah, IA
    For local club use purposes I share the link to the map on my Google Drive since the limited number of participants only need to access it for a finite period of time; however, that approach wouldn't be a good, elegant, or permanent solution for a longer-term MA map repository. Hopefully there is an XF plugin or suitable alternative.
  8. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Still looking into this.. but some other things came up (server move in particular).. will get back on this soon.
  9. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Quick update - the server move to the new hosting company is in process. We will do the initial data migration and testing.. then schedule the move. Once that is done, I will begin working on this again.. its a little more complex than I thought to get this updated. But will figure out a way. :D
    • Optimistic Optimistic x 1
  10. MCS02
    Good luck we're all counting on you!
  11. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Thanks! Can't wait to get this done so I can get back to working on the front end stuff... :D
