GNAT - Rebuild - The Sequel
Discussion in 'Car Builds, Projects, Idea's Experiments' started by Nathan, May 11, 2015.
  1. DryMartini
    DryMartini New Member
    Dec 6, 2012
    1,048
    479
    Yep, that head is definitely No. 2 now.
  2. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    Will you have those injectors tested and calibrated, I suspect that one. The O2 wire would probably have caused the all the rest to show a lean condition if that were the culprit.
    That cylinder took a #2 all right....
    I'd not thought of having the injectors cleaned, tested and calibrated. Chad and Nick are monitoring this thread, their thoughts on this would be beneficial.
    I would have no idea where to have that service performed either. Google offers dozens of choices.
  5. cct1
    Damn, might be cheaper to buy new injectors, be interesting to see what they charge.
  6. Metalman
    Less than the cost of one to have this done from the link provided by Metalman
    $22 each
    $10 return shipping
    $98 + shipping to them.
    Approx 6 day turnaround from receipt to shipped.
  8. cct1
    That's better than I thought, looks good.
  9. TheModFather
    What injectors do you have Nate? Might be worth it to upgrade while the labor is free... ;)
  10. Nathan
    Ummm...
    I think I have 550's
  11. Detroit Tuned
    319
    evertyhing
    Metro Detroit
    #51 Detroit Tuned, May 27, 2015
    As promised the video!
    [ame="https://www.youtube.com/watch?v=XNCxM3hpoVU"]NatesHead - YouTube[/ame]
    Sorry about the bad edit. It was quick and by hand.
    Injector testing is never a bad idea. We have the time. :)
  12. Minidave
    Whadya think - just one of those things? valve just broke? the color looks good on all the valves, doesn't look like it went lean at all.....
    He would have had to have been at full throttle for a long time for it to burn a valve like that - to me. Like doing laps around Texas Motor Speedway or sumthin......
    I'm absolutely astounded the piston in #2 hole looks that good. Even though you have had bad juju with the head it could have been far far worse. Go buy a lottery ticket Nathan, you have a good luck streak going.
  14. Norm03s
    Norm03s New Member
    534
    That cylinder was running lean for sure look at the other valve, same color, lean. Compare to all the others. Maybe the best indicator is the color inside the exhaust ports in the header.
    Idealy, monitoring and tuning the each injector to get the same temp. in each cylinder will get the most performance.
  15. BlimeyCabrio
    I've thought (several times) about installing EGT probes in all four primaries. It really is the best way to do it. But then I think "OMG that's overkill..."
    I'm about to install a single EGT probe at the collector... which provides interesting info, but not really the useful data I'd like to have.
  16. Norm03s
    Norm03s New Member
    534
    The high end tuners dial in each cylinder, what's overkill?
  17. BlimeyCabrio
    Every dollar I spend on that... is a dollar that can't be spent elsewhere... that's all.
  18. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    When R53s run lean, it's cylinder #4 exhaust valves that melt, not #2. If the motor was running lean (all cylinders), or Nathan was getting no signal from the O2 sensor, he would have seen it on his gauge, which would have been a major red flag (the gauge provides the signal to the VIPEC). You could easily ohm out the wire to see if it is conducting, but based upon the symptoms, It looks to me that the injector is the more likely culprit.
  19. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    Correct - I know that from first hand experience when my meth system failed on me during a tuning run. There is an adjustment in the Vipec where you can change an additional fuel trim for each cylinder to compensate for the differences in flow due to manifold design.
  20. Nathan
    So...
    Does the combined braintrust think I should send the injectors out to be cleaned and tested?
    If so, any recommendations at to where to send them?
