GNAT - Rebuild - The Sequel
Discussion in 'Car Builds, Projects, Idea's Experiments' started by Nathan, May 11, 2015.
    Not really.
    The engine mount from Greene performance has been delivered to Detroit tuned.
    Jan is having a head gasket made. since It's bored over the OEM one won't fit correctly. Also the head has been milled so there needs to a bit more height to the gasket.
  2. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
    So when you are in this situation is it better to plan for what if and have a spare gasket made at the same time?
    Never had this so I don't know what kind of turn around it takes to get one made ad hoc.
  3. Minidave
    Is it being cut from copper sheet?
  4. Dave.0
    I think it would be a copper core with reflex style graphite style coating for a perfect seal.
    Updates!
    Jan shipped today. Woohoo...
    So, what am I getting that I'm not even going to get to see in the flesh....
    Injectors - clean, calibrate, new o-rings and pigtails. The reports on the injectors are in the box. I'll post them at a later date.
    Head has new seats installed, new guides installed, CNC'd chambers, new springs, single groove keepers, titanium retainers, 1.8mm oversized Intake valves, 2.3mm oversized inconel exhaust valves all replaced
    Head Gasket - 78mm .050 thick
    RMW Dominator Camshaft
    I'm Happy.
  6. Firebro17
    Happy, Happy - Joy, Joy! :Thumbsup:
  7. AAONMS
    AAONMS Well-Known Member
    5,027
    221
    I play with trains...
    Fruit Cove, FL
    Great news
  8. nxtMINI
    nxtMINI Active Member
    Apr 26, 2010
    405
    40
    Michigan
    Fantastic! one step closer to getting gnat back
  9. Dave.0
    Don't forget the correct plugs and get it tuned this time. :eek:
  10. Batrugger
    Batrugger New Member
    May 13, 2009
    463
    92
    Soldier
    Hesperia, Ca.
    Glad to hear. RMW deliveries are always good. Looking forward to it being finished.
  11. Jan
    Jan Well-Known Member
    377
    382
    #111 Jan, Jul 29, 2015
    forgot to post these before.............
    so after tearing the head apart we found out the reasons why it failed
    Nathan had another shop in the past work on the head ..........and in their not so infinite wisdom ,put expoxy in the INTAKE ports. As you can see from the pics it was chunking out and into the combustion chambers. Some of the expoxy got stuck under the exhaust valve and caused it to burn the valve.
    They had also shimmed the springs to where it was coil binding. Which explains why when I drove the car the car was soft on power.
    All new springs now, new valves, new guides etc.........It's like a brand new head again. Can't wait for Nate to see the new found power.
      File size:
      1.7 MB
      341
      File size:
      2.2 MB
      298
  12. Minidave
    Were they trying to reshape the ports with the epoxy for better flow?
  13. Ryephile
    Ryephile New Member
    Apr 9, 2009
    299
    122
    Yes!
    Metro Detroit
    Good to see you found the problem Jan.
    Best of luck to Nathan in getting GNAT back up and running stronger than ever!
  14. Batrugger
    May 13, 2009
    463
    92
    Soldier
    Hesperia, Ca.
    Wow that's just nuts.
  15. Jan
    377
    382
    yes..........I guess he thought he was a better porter than the guy with more records than God.........:devil:
  16. Nathan
    That was to weld a crack. Yeah, that didn't work.
    I had no idea at the time this is how they "fixed" it before.
  17. Zapski
  18. Minidave
    Ha!
    Yeah, I can't imagine epoxy as a good material for that application.....and spring coil binding? Come on - that's cylinder head 101 fer chrisakes!
    We are Groot!
  19. Jan
    377
    382
    there was no cracks in the head and the only welding was on the stud for the intake manifold so I am not sure what was done besides adding the epoxy and the crazy shimming of the springs. Oh well........it's good now:Thumbsup:
  20. cct1
    Epoxy on a hot Iron block?
    Duct tape, that's always the answer.
