GNAT - Rebuild - The Sequel
Discussion in 'Car Builds, Projects, Idea's Experiments' started by Nathan, May 11, 2015.
  1. Minidave
    Like Jan says, it's all good now! :Thumbsup:
  2. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    Sounds like a plan...and if you need a ride up to pick up your car, let me know. It may be time for brakes...
  3. BlimeyCabrio
    What.... The.... Frack....
    Unreal
  4. TheModFather
    Was this done by MINIcorsa? W T F ! ! !
    No, it was in Dallas. The shop is gone, the land sold to the state to widen I-35E.
  6. TheModFather
    Ah... Making more sense now.
  7. old81
    Good to see what expert hands and eyes can see and fix. :)
    It will be great to see Gnat back up to full powers and solid.
  8. Zapski
    Seems a better use of the land, if you ask me.
  9. Nathan
    Had a quick Chad Chat today. All the parts are there now. Slated to start Friday on getting it up and running first. From there we'll explore a bit of a wish list.
    I understand the head gasket is rather thick. Hopefully the crack Detroit tuned team will take a few snap shots along the way.
  10. Jan
    Jan Well-Known Member
    377
    382
    50thou...........
    T'would be helpful if you'd please explain it to us like we are 5. :D
  12. Jan
    377
    382
    50 thousandths of an inch thick
  13. Metalman
    #133 Metalman, Aug 6, 2015
    .050"
    1.27mm
  14. Nathan
    I was thinking it may be helpful to explain why this head gasket is different than OEM.
    Hence...
  15. BlimeyCabrio
    Because you keep destroying things, so they keep grinding more and more off the bottom of your head, and you gotta make that up somewhere...
  16. Metalman
    Now go sit in the corner Nathan...
  17. Zapski
    When a Mommy block and a Daddy cylinder head love each other very much....
    I am so not going to finish this.
  18. Batrugger
    Batrugger New Member
    May 13, 2009
    463
    92
    Soldier
    Hesperia, Ca.
    Because the head and block have been decked to ensure the surfaces are flat and true in order to make a good seal, material was ground off. The gasket has to be thicker to make up for the material. If not, compression would be raised, pistons could hit valves, and the chain would be loose because the cam sprocket would be sitting lower.
  19. Ryephile
    Ryephile New Member
    Apr 9, 2009
    299
    122
    Yes!
    Metro Detroit
    Is it weird that I know that conversion right off the top of my head? :blush2:
  20. Metalman
    Move the decimal point one digit to the right and you get...
    .50"
    12.7mm
    And you can feed this....
