Engine Drivetrain 1st Gen Cooper S GNAT - The Resurrection
Discussion in 'Tuning and Performance' started by Nathan, Feb 23, 2012.
  1. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    What are the specs on the motor build?
    Oil pick up with RMW thingie that prevents oil starvation during sustained high load cornering. BTW, much like the head, it is one of the first produced.
    I do believe The Chad is working late this evening. Pictures keep popping up on my phone.
  4. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    Oil Windage Tray
  5. Metalman
    ^^^ Why do I get the idea that Beano is missing out on a great opportunity to co-brand a great product? Could be a good intro for a racin sponsorship. Just sayin....:D
  6. Minidave
    I always thought a windage tray was more of a flat piece of sheet metal that separated the crank from the oil, so the motion of the crank wouldn't cause the oil to froth and foam - also called a crank scraper.
    Looks like this....
    The item on the oil pump I think is called an antisurge cage - lets the oil into the sump area, won't let it out.
    Here's one in the bottom of an oil pan, rather than mounted to the pump pick up tube....the hinged flaps allow the oil to flow to the pick up, but won't let it back out again under cornering forces.
  7. Tüls
    Tüls New Member
    Apr 3, 2009
    438
    12
    The sky
    High comp huh? Interesting.
  8. Jan
    Jan Well-Known Member
    377
    382
    actually stock compression............
    we raised the piston to sit flush in the block for better quench area and dished the piston with a slight mound in it for better swirl..........:Thumbsup:
    cuts down on detonation:devil:
  9. Redbeard
    1,636
    398
    I'm not anywhere near an engine builder in my knowledge but I'm always interested to learn more. Hence honest questions: What is the quench area? What do you mean by swirl and how does that effect detonation? Does that make the piston a hemi?
  10. Nathan
    New pictures ....
  11. Metalman
    Nathan.... I don't think your engine has ever had it this good.....:D
    It's being pampered at Chad's motor spa.... :D
  13. Mr. Jim
    When are the t-shirts going on sale :)
  14. minimark
    Nathan's wallet's going to need a spa treatment when all's said and done... Lol
    .....but well worth it!!! :cool:
  15. Nathan
    I've been saving for this for a while. I knew it was just a matter of time. Also have to thank Jan for helping me out on some parts. That was very nice of him, he sure didn't have to.
    Chad has been very easy to work with as well...
    But, a few more Supporting Members wouldn't hurt...
    I think my membership bought you an oil change.... :smilewinkgrin:
  17. Dave.0
    Your motor is looking Real good Nathan, few RMW parts, a little Motor city know how from Chad and you will set for one FUN time at this years Dragon and many future ones.:D:Thumbsup:
  18. Gil-galad
    Gil-galad Club Coordinator
    May 19, 2009
    1,178
    431
    Decorah, IA
    Actually, this idea has some merit. I, for one, would give serious consideration to investing in a tee commemorating this historical event -- something particularly clever about the rebuild, tack on some DT, RMW, and MA logos, etc. and there you have it. Probably have to sell a bunch to make a difference, but who knows?
  19. Mr. Jim
    See I told ya. ;-)
  20. Redbeard
    1,636
    398
    I'd buy one. Nathan would have to put a pic of his ride on it though. Cartoon or otherwise.
